I recently purchased a MBL 3TB with the latest firmware 02.32.06-006 pre installed. My MBL constantly wakes from sleeping for no apparent reason. I do have photos in the public share but these have already been transcoded. Does anyone else suffer from the same problem?
Anyone else can comment?
Log in via SSH and post the last 40 or 50 lines of the file
/var/log/messages
(Or you can get to the same file by doing a diagnostic report from the UI.)
It will tell you how often it is waking up.
Log entries:
Feb 3 20:09:56 MyBookLive [admin-rest-api.preinst] 02/03/13 20:09:56: test
Feb 3 20:09:56 MyBookLive [admin-rest-api.preinst] 02/03/13 20:09:56: test()
Feb 3 20:09:56 MyBookLive [admin-rest-api.preinst] 02/03/13 20:09:56: done.
Feb 3 20:09:57 MyBookLive [admin-rest-api.postinst] 02/03/13 20:09:57: test context=test
Feb 3 20:09:57 MyBookLive [admin-rest-api.postinst] 02/03/13 20:09:57: permissions check for //var/www/Admin/webapp/config: PASSED
Feb 3 20:09:57 MyBookLive [admin-rest-api.postinst] 02/03/13 20:09:57: permissions check for /dynamicconfig.ini: FAILED
Feb 3 20:09:57 MyBookLive [admin-rest-api.postinst] 02/03/13 20:09:57: permissions check for //usr/local/nas/orion/: PASSED
Feb 3 20:09:57 MyBookLive [admin-rest-api.postinst] 02/03/13 20:09:57: permissions check for //usr/local/nas/orion//orion.db: PASSED
Feb 3 20:09:57 MyBookLive [admin-rest-api.postinst] 02/03/13 20:09:57: setup test for admin-rest-api: PASSED
Feb 3 20:09:57 MyBookLive [admin-rest-api.postinst] 02/03/13 20:09:57: done.
Feb 3 20:09:57 MyBookLive _: pkg: upnp-nas
Feb 3 20:09:57 MyBookLive _: pkg: dlna-server-twonky
Feb 3 20:09:57 MyBookLive _: pkg: nas-safepoint
Feb 3 20:09:58 MyBookLive _: pkg: webui
Feb 3 20:09:58 MyBookLive _: pkg: orion-resources
Feb 3 20:09:58 MyBookLive _: pkg: afp
Feb 3 20:09:59 MyBookLive _: pkg: sw-nas-inst
Feb 3 20:09:59 MyBookLive kernel: Adding 500608k swap on /dev/sda3. Priority:-1 extents:1 across:500608k
Feb 3 20:10:01 MyBookLive S99wdInitFinalize: begin script: start
Feb 3 20:10:02 MyBookLive S99wdInitFinalize: currentRootDevice is set to /dev/md0
Feb 3 20:10:02 MyBookLive S99wdInitFinalize: currentRootDevice = /dev/md0
Feb 3 20:10:02 MyBookLive S99wdInitFinalize: Running final checks… (version 02.32.06-006 on /dev/md0)
Feb 3 20:10:02 MyBookLive S99wdInitFinalize: #-------------------------------------------#
Feb 3 20:10:02 MyBookLive S99wdInitFinalize: System restart: current version is 02.32.06-006
Feb 3 20:10:02 MyBookLive _: run pkg bootup scripts:
Feb 3 20:10:02 MyBookLive [bootscript_000_nas-safepoint] 02/03/13 20:10:02: ( boot-system ) begin
Feb 3 20:10:02 MyBookLive [bootscript_000_nas-safepoint] 02/03/13 20:10:02: done.
Feb 3 20:10:02 MyBookLive [bootscript_000_wd-nas] 02/03/13 20:10:02: ( boot-system ) begin
Feb 3 20:10:02 MyBookLive [bootscript_000_wd-nas] 02/03/13 20:10:02: done.
Feb 3 20:10:02 MyBookLive [bootscript_000_webui] 02/03/13 20:10:02: ( boot-system ) begin
Feb 3 20:10:02 MyBookLive [bootscript_000_webui] 02/03/13 20:10:02: done.
Feb 3 20:10:02 MyBookLive [bootscript_001_networking-general] 02/03/13 20:10:02: ( boot-system ) begin
Feb 3 20:10:02 MyBookLive logger: hostname=MyBookLive
Feb 3 20:10:02 MyBookLive [bootscript_001_networking-general] 02/03/13 20:10:02: done.
Feb 3 20:10:02 MyBookLive apache2: 192.168.0.10 WebUI::session_start()
Feb 3 20:10:02 MyBookLive [bootscript_075_orion-resources] 02/03/13 20:10:02: ( boot-system ) begin
Feb 3 20:10:02 MyBookLive [bootscript_075_orion-resources] 02/03/13 20:10:02: done.
Feb 3 20:10:03 MyBookLive [bootscript_085_wd-lib] 02/03/13 20:10:02: ( boot-system ) begin
Feb 3 20:10:03 MyBookLive [bootscript_085_wd-lib] 02/03/13 20:10:02: pkg wd-lib () system boot…
Feb 3 20:10:03 MyBookLive [bootscript_085_wd-lib] 02/03/13 20:10:02: done
Feb 3 20:10:03 MyBookLive [bootscript_095_admin-rest-api] 02/03/13 20:10:03: ( boot-system ) begin
Feb 3 20:10:07 MyBookLive apache2: 192.168.0.10 WebUI::session_start()
Feb 3 20:10:11 MyBookLive [bootscript_095_admin-rest-api] 02/03/13 20:10:11: done.
Feb 3 20:10:12 MyBookLive [bootscript_999_sw-nas-inst] 02/03/13 20:10:12: ( boot-system ) begin
Feb 3 20:10:12 MyBookLive [bootscript_999_sw-nas-inst] 02/03/13 20:10:12: done.
Feb 3 20:10:12 MyBookLive S99wdInitFinalize: Check if new firmware is available
Feb 3 20:10:15 MyBookLive apache2: 192.168.0.10 WebUI::session_start()
Feb 3 20:10:15 MyBookLive S99wdInitFinalize: Rotate logs
Feb 3 20:10:23 MyBookLive apache2: 192.168.0.10 WebUI::session_start()
Feb 3 20:10:24 MyBookLive logger: WD NAS: Email alerts sent OK
Feb 3 20:11:20 MyBookLive logger: /usr/local/sbin/monitorio.sh: waiting for system to become ready…
Feb 3 20:11:20 MyBookLive kernel: svc: failed to register lockdv1 RPC service (errno 97).
Feb 3 20:11:30 MyBookLive logger: /usr/local/sbin/monitorio.sh: waiting for system to become ready…
Feb 3 20:11:39 MyBookLive logger: Starting orion services: miocrawlerd, mediacrawlerd, communicationmanagerd
Feb 3 20:11:39 MyBookLive logger: /usr/local/sbin/monitorio.sh: waiting for system to become ready…
Feb 3 20:11:42 MyBookLive : System ready
Feb 3 20:41:53 MyBookLive logger: exit standby after 7 (since 2013-02-03 20:41:46.391397819 +0000)
Feb 3 21:01:58 MyBookLive logger: exit standby after 596 (since 2013-02-03 20:52:02.415399985 +0000)
Feb 3 22:58:06 MyBookLive logger: exit standby after 7 (since 2013-02-03 22:57:59.159391232 +0000)
Feb 3 23:09:14 MyBookLive logger: exit standby after 61 (since 2013-02-03 23:08:13.943399947 +0000)
Feb 3 23:53:01 MyBookLive logger: exit standby after 193 (since 2013-02-03 23:49:48.347399757 +0000)
Feb 4 00:13:28 MyBookLive logger: exit standby after 11 (since 2013-02-04 00:13:17.903400789 +0000)
Feb 4 00:35:43 MyBookLive logger: exit standby after 118 (since 2013-02-04 00:33:45.191399474 +0000)
Feb 4 01:27:58 MyBookLive logger: exit standby after 94 (since 2013-02-04 01:26:24.867400545 +0000)
Feb 4 02:00:12 MyBookLive logger: exit standby after 109 (since 2013-02-04 01:58:23.931400685 +0000)
Feb 4 02:52:22 MyBookLive logger: exit standby after 88 (since 2013-02-04 02:50:54.475399298 +0000)
Feb 4 03:05:01 MyBookLive kernel: md: cannot remove active disk sda1 from md0 …
Feb 4 03:05:01 MyBookLive kernel: md: cannot remove active disk sda2 from md0 …
Feb 4 03:54:47 MyBookLive logger: exit standby after 94 (since 2013-02-04 03:53:13.399399772 +0000)
Feb 4 04:37:01 MyBookLive logger: exit standby after 100 (since 2013-02-04 04:35:21.679399810 +0000)
Feb 4 05:18:18 MyBookLive logger: exit standby after 43 (since 2013-02-04 05:17:35.683400783 +0000)
Feb 4 05:40:29 MyBookLive logger: exit standby after 114 (since 2013-02-04 05:38:35.207401172 +0000)
Feb 4 06:01:41 MyBookLive logger: exit standby after 55 (since 2013-02-04 06:00:46.327399966 +0000)
Feb 4 06:12:47 MyBookLive logger: exit standby after 58 (since 2013-02-04 06:11:49.975399745 +0000)
