I just bought this and am I led to believe the unit does not carry HULU plus even though it clearly shows the logo on the box? I don’t see it anywhere in the menu at all. Something tells me I should have stuck with my instincts and bought the Net___ brand!!
If not – this thing goes back to Stapes!
It most definitely does support Hulu Plus.
Have you looked under ALL SERVICES (the little bell icon at the top of the screen).
… and do you live in a territory where Hulu Plus is “allowed?”
This is all I get … No “bell” icon visable either
I am in California
Sorry, yeah, it’s not a bell. But you found it anyway…
You’re actually missing THREE apps.
I have 33, you have 30.
… and you have an app which hasn’t existed in ages: Deezer.
You’re also missing Pandora and two others.
Are you running the latest version, and have you tried resetting the box back to defaults?
I have the same issue – I just bought WD TV Play, and stright out of the box, Hulu does not show. I’m in Austin TX, using Time-Warner Cable, and running the latest firmware.
I also have a WDTV Live, and on Saturday the Hulu I’be been watching for over a year disappeared from that box. Reverting to an older firmware did not recover Hulu; resetting all setting did not recover Hulu, and re-updating to latest firmware did not recover Hulu.
Any ideas? Could Time-Warner have blocked Hulu?
I have the exact same issue. Just set up the unit today, but no Hulu+.
Tried all kinds of regional changes and resets, nothing.
Any help resolving this would be immensely appreciated
Found the solution!!
Simply change your time region to ‘central America’ , apply and then say ‘restart device’.
Done. Hulu and Pandora listed
