Hey all,
I looked and can’t find anyone with a similar problem:
I’ve got the WD Live player, trying to watch MKV files, but no video. AVI files work perfectly, but MKV files play the sound perfectly but just a black screen for video.
Anyone help?
Hey all,
Anyone help?
Post the text output of MediaInfo for such a file.
Also what firmware is on your WDTV.
General
Unique ID : 135579885360263327028298601009573891511 (0x65FFBC71855BE35A086AED12D5898DB7)
Complete name : C:\Users\GremlinBoi\Wombles, The [1X01] - New Year, New You.mkv
Format : Matroska
File size : 117 MiB
Duration : 10mn 2s
Overall bit rate : 1 631 Kbps
Writing application : Lavf52.39.0
Writing library : Lavf52.39.0
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : V_MPEG4/ISO/ASP
Codec ID/Info : Advanced Simple Profile
Bit rate : 1 471 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Writing library : Lavc52.36.0
Language : English
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : A_MPEG/L3
Codec ID/Hint : MP3
Duration : 10mn 2s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 9.19 MiB (8%)
Language : English
RichUK - The latest update for WD Live - 1.04.22_v
Does this help either of you to help me? ![]()
I am not sure, but I don’t think the WDTVs support h.263 video.
I have also a simular problem but different ![]()
My hub play mkv format but no sound??
Can anyone help me?
Where is your MEDIAINFO report?
