I’m having an MKV files hanging problem on my wd tv (I don’t know if a file with header compression caused it, as I’ve deleted the file that first had this problem). Suddenly I can play avi files, but have problems with all the mkv files (including known good ones that had no problem playing before). They hang when I try to play them, and I have to press the pause\play button a few times untill they actually play (it does happen eventually, but I have to mess with every file untill it does, quite annoying). I did a full reset + restore factory setting on my wd tv, but to no avail.
I’m thinking this might be a network problem, as there is no problem playing the same files from a disk-on-key I stick into the streamer. It only happens when I go to my network shares (the wd tv is connected with a network wire to a router, that is connceted to a pc with windows xp).
Ideas, anyone?
