I’m using a WD TV HD.
Recently I just ran into a file which my media player cannot play. Searched forums and I found out that there are mkv files that can mess up the WD TV. I had to do the usual reboot, return to factory settings and everything worked again.
Now, with regard to the file the messed everything up, I tried to look for a solution to get it to work. I found in this same forum ( http://community.wdc.com/t5/General-Discussions/WD-TV-Live-won-t-play-video-all-of-sudden/td-p/11691)) that I can run the file in MKVMerge that is version 4.0 or earlier to make sure I get the correct file (something about header compression which I don’t undertstand anyway).
I tried it and got the below error message:
mkvmerge v2.2.0 (‘Turn It On Again’) built on Mar  4 2008 13:20:12
‘E:\Movies\HD 1080p\The Town [2010].mkv’: Using the Matroska demultiplexer.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 1: Using the MPEG-4 part 10 (AVC) video output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 2: Using the DTS output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 3: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 4: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 5: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 6: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 7: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 8: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 9: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 10: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 11: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 12: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 13: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 14: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 15: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 16: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 17: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 18: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 19: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 20: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 21: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 22: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 23: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 24: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 25: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 26: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 27: Using the text subtitle output module.
‘E:\Movies\HD 1080p\The Town [2010].mkv’ track 28: Using the text subtitle output module.
The file ‘E:\Movies\HD 1080p\The Town Mux.mkv’ has been opened for writing.
progress: 1%progress: 1%progress: 1%progress: 1%progress: 1%progress: 1%progress: 1%progress: 1%progress: 1%progress: 1%progress: 1%progress: 1%progress: 1%progress: 1%progress: 1%progress: 1%progress: 1%progress: 1%‘die’ called: common.cpp/safemalloc() called from file src/common/compression.cpp, line 266: malloc() returned NULL for a size of 53195 bytes.
Just for added info, here’s the media info of the file that won’t play:
General
Unique ID                        : 222510486863266345429271084541089324322 (0xA765F60168F512B7B5A4A56999EE9D22)
Complete name                    : E:\Movies\HD 1080p\The Town [2010].mkv
Format                           : Matroska
File size                        : 4.66 GiB
Duration                         : 2h 4mn
Overall bit rate                 : 5 352 Kbps
Encoded date                     : UTC 2011-03-24 16:36:42
Writing application              : mkvmerge v4.5.0 (‘Speed of Light’) built on Feb  1 2011 02:10:32
Writing library                  : libebml v1.2.0 + libmatroska v1.1.0
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L4.0
Format settings, CABAC           : Yes
Format settings, ReFrames        : 4 frames
Muxing mode                      : Header stripping
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 2h 4mn
Bit rate                         : 4 600 Kbps
Width                            : 1 920 pixels
Height                           : 800 pixels
Display aspect ratio             : 2.40:1
Frame rate mode                  : Variable
Frame rate                       : 23.976 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.125
Stream size                      : 3.91 GiB (84%)
Title                            : The Town (2010) 1080p [mkvonly]
Writing library                  : x264 core 88
Encoding settings                : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=4600 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language                         : English
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format                           : DTS
Format/Info                      : Digital Theater Systems
Codec ID                         : A_DTS
Duration                         : 2h 4mn
Bit rate mode                    : Constant
Bit rate                         : 755 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Sampling rate                    : 48.0 KHz
Bit depth                        : 24 bits
Compression mode                 : Lossy
Stream size                      : 673 MiB (14%)
Language                         : English
Not sure how to proceed on this error.
Is there a fix or upragde for the WD TV HD which will make it play files like this? Or is there something I missed that’s why it won’t mux?
Really need your help, guys. Thanks!
