More Folder problems
Hi there.  I have the WD hub with latest firm.  I have been struggling getting the folder.jpg to refresh.  It keeps pulling in a old version.  I have searched and tried everything.
I have renamed the folder, deleted the thumb directory.  The only solution I have is to make a new folder and move my movies.
There must be a place where the WD stores a cache based on the folder name or something.  I have even deleted the folder and the thumbs in the thumb dir, rebooted, and remade the directory.  It still pulls in the old jpg.
Very frustrated with this.  If I ever want to change the folder image, I wont be able to.
Any sugestions?
1st suggestion … post in the correct forum
http://community.wd.com/t5/WD-TV-Live-Hub-Discussions/bd-p/wdtvlivehub
2nd suggestion … delete the .wd_tv/thumb folder and the .miocrawler_cache folder (if you have one) then reboot
3rd suggestion … clear the Media Library  eg.  Setup > System > Media Library > Clear Media Library
Thanks for the reply.  My bad on the wrong forum.  I will repost there.
I tried suggestion 2 already.  The old image keeps returning.
I will try suggestion 3.
Jason
no probs, i’ve notified a moderator to move this post  (so you don’t have to repost)
also, a 4th suggestion … ‘rename’ the folder  eg.  “Movies”   to   “My Movies”  and then reboot
(i know it’s a pain, but not as much as “moving” the contents … also you can rename the folder back to Movies after the reboot and the folder.jpg image will be the “new” one)
Thanks.
I already tried your suggestion.  Did not work.  When I renamed it back to the original folder name, the old image came creaping back.  Thats when i figured the image must be cached somewhere.  That is when I deleted .microcrawler folder.  So I ended up renaming the folder and moving all the files.
I’ll have to hope I never want to change it again.  I’ll play with it again tomorrow.
