Hey there,
I have some trouble with my Thumbgen settings. Whenever the background slideshow should run, there is just a plain black screen. May someone can help me out with the proper settings (best with screenshots). I put up here some screenshots of my settings and movie menu, too.
I use a WD TV LIVE C3H media player with a 2.01.86 firmware.
Thanks in advance.
Greetings
My setup is a little different (i scrape from XBMC .nfo files) … but, outlined in RED is where you have gone wrong
1) Moviesheets must be a *.jpg (not *.metathumb)
also $M$N$E_sheet should be $M$N_sheet ($E puts a file extension in the sheet name which is not necessary for standard movie sheets)
i would also “uncheck” “Extra Thumbnail” in the General Option …it’s not needed
I would recommend “check” Main / Extra moviesheet metadata in the General Options (this generates a *tgmd file … which is basically a *zip file that contains all the metadata (Covers,Backdrops,Info etc)
If you wish to re-generate different moviesheet templates at a later date… this can be done quickly (without being online) … on the Process Files/Folder screen select “Create from Metadata”
- If you want local sheets to be displayed this is the correct setting (when you open the *.xml you will see this …
rg. Interstellar_sheet.jpg … this will display the local sheet)
