MY book duo drive in my cloud duo
I am planning to buy 24 tb my duo with an intention that I could be able to take one of the 12 tb drive out and used it in My clould Ex2 enclosure.
  1. Can I take one on the drive out from my book to use in my cloud?
  2. Will my clould support 12tb hard disk.
Both the discussed product are mentioned below:
M
Not sure which subforum you should see but try the My Cloud EX subforum where users more familiar with the EX2 Ultra may be able to assist. Or see the dedicated subforum for the My Book Duo. Both of those devices are different than the device generally discussed in this subforum (the single bay/single drive My Cloud).
http://wdstagingsplit.staged-by-discourse.com/
