Hello.I have a My Book Live Duo(WDBVHT0040JCH) external drive.I want to replace the standard drives(model WD20EURS) from inside with two WD RED PRO drives(model WD2002FFSX).Is it possible?The red pro drives are compatible with my book live duo?I know that wd red pro have higher power consumption so will the unit provide the necessary power to the drives?
I believe you can only replace the internal drives with drives that have identical model number to the drives included in your enclosure.
Take a look at this link for more information:
https://support.wdc.com/knowledgebase/answer.aspx?ID=8644&lang=en
