- My Book Live Duo (MBLD) on Window 7 Professional x64
- Netgear WNR2000v3 wireless router
- computer connected via wireless
Problems:
- CD setup does not discover the MBLD
- MBLD is not discovered as a UPnP device
- MBLD is not discovered by WD QuickView
- MBLD is not discovered by WD Smart Ware
- I cannot get to the Dashboard using http://mybookliveduo/
However, I can:
- see MBLD as an Attached Device on the router with the name MYBOOKLIVEDUO
- get to the Dashboard using the IP address (e.g., http://192.168.1.3)
- browse the file system using the IP address (e.g., [\192.168.1.3](file://%5C%5C192.168.1.3))
I have already:
- reset the MBLD
- reset the router
- restarted the computer
- installed the latest MBLD firmware
- installed the latest router firmware
- installed the latest Windows Updates
The computer is part of an AD Domain at work, but this MBLD setup is for my simple home network.
Please advise.
