My Book pro II : are WD RED disks compatible?
Can I put the new wd red disk into a My book pro II unit?. Thanks.
Cesar
According to a note found on page # 24 of the User’s manual it only supports WD Black drives.
Important: Only use WD Black™ hard drives to replace the drives in your My Book Pro
device enclosure. Also, replacement drives must be new, and the same capacity as the
drive that failed. The RAID configurations require both drives to be the same capacity.
Using any other hard drive or capacity voids the warranty for your My Book Pro device
Thank you for your answer, but it isnt’n my device, mine is My BookTM Pro
EditionTM II.
Best
César Prieto
Can you please share the model number of your drive?
I found this one:
But it does not specify what type of drives it is compatible with.
I guess you will have to contact WD support directly for assistance with his.
Model: WDBGPU0010BBY-OB
My Passport Ultra 1Gb
