My Cloud dashboard is not updated/Faulty/
Plz Help dummies !
I am running V 2.30.165 but my dashboard does not give me the option to install an app. There is no + button on the APP page on the dashboard.
What do i do.
Nothing. The My Cloud single-bay NAS doesn’t support the addition of more apps.
That’s a feature reserved for the 2-bay or higher-end models.
Well, Not “officially” anyway…
If continued warranty coverage of the device is not a concern, look into Fox_Exe 's handy litle ‘wdcrack’ package. It persistently enables quite a few handy freatures on the single bay myclouds.
Have you read the User Manual and all Help information provided?
There are NO apps to officially install. Do a forum search, magnifying glass icon upper right, as this is a well discussed limitation of the second generation single bay My Cloud units. Only the My Cloud Mirror and above units support third party apps.
Unofficially there is a way, using SSH to modify the v2.x single bay My Cloud firmware, to enable adding certain third party apps. This is NOT supported by WD. See the following discussion:
http://wdstagingsplit.staged-by-discourse.com/t/wd-mycloud-gen2-enable-apps-install-tab-apps/177885/
