My Cloud EX2 Ultra web portal reports drive as having a fault but SMART shows no problem
I’ve noticed that My Cloud EX2 Ultra web portal started showing a Caution indicator:
Clicking on it shows some sort of Fault:
The Storage panel shows one of disks as being “Bad”. Clicking the SMART Data link opens a rather truncated panel showing no useful hints of what is wrong. There are no raw values to check, no SMART errors, and no failure indicators.
Checking the data via smartctl shows no problems for either of the drives:
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%     50368         -
# 2  Short offline       Completed without error       00%     50363         -
# 3  Short offline       Completed without error       00%         0         -
# 4  Short offline       Completed without error       00%         0         -
So, what is the problem? What is the web portal warning me about?
How are the drives configured? JBOD? Raid 0? Raid 1?
In the meantime, I would not turn it off (cycle power) assuming you can still access all of your files. I’d backup all critical files to another drive/location before you do anything else.
In the dashboard, go to Settings/Utilities and under System Diagnostics, select View logs. You can filter the results to make scrolling through them easier.
I would run the quick test AFTER you backup your files. If passed, run the full test.
Configuration is RAID 1. Only one drive seems to be having issues so panic level is low.
Logs have no Critical entries and a few CIFS failed logins.
I’m not sure what the “Tests” in the web panel too, but the Short one seems to simply execute smartctl -t short for both drives. The web panel reports no errors and there’s a new entry in the smartctl output for the test.
I’ll check what the full test does, but thus far the problem is still there - MyCloud web portal reports an error, but is there an error?
There is an error with one of the drives after all. A Full self test resulted in the following:
Disk1	Passed - Full disk test completed successfully.
Disk2	Failed - Full disk test failed. Please backup your data and replace this disk. If you need further assistance, contact WD Support.
smartctl for the second drives shows an error too:
# 1  Extended offline    Completed: read failure       90%     44424         10741472
# 2  Short offline       Completed without error       00%     44424         -
# 3  Extended offline    Completed without error       00%     44401         -
# 4  Short offline       Completed without error       00%     44396         -
# 5  Short offline       Completed without error       00%         0         -
# 6  Short offline       Completed without error       00%         0         -
Thanks for the tip @Saudade. That’s enough to warrant a replacement.
Two interesting points about this. Two SMART Extended tests are logged only 23h apart, both occurred when the drive was already failing. The earlier one was initiated by smartcl -t long and came up clean, while the later one started by clicking Full test from MyCloud web portal reported an error. The second point is that MyCloud web portal logged a failure before any SMART indicators did.
Well, I guess I’m glad your drive is bad (and not your EX2). At least you have confirmation. Good news, it’s an easy fix.
