My cloud keeps losing connection
My WD MYCloud keeps shoing yellow on the power indicator. I am tired of pulling the plug and putting it back it for re connection. Maybe I should get a netgear cloud device.
should I get a Netgear switch to connect my wireless router and my WD cloud device to instead of connecting my cloud device into the wireless router
Did you try what Rac8006 suggested in the previous thread you started in the My Cloud loosing connection? If so what were the results?
http://wdstagingsplit.staged-by-discourse.com/t/light-keeps-going-from-blue-to-yellow/154304/4
