Hi guys,
I just want to share with you my opinion after 5 months of using WD Mycloud EX2. So when i’ve started to check the market for a new NAS, there were ALOT of options:Qnap, Synology, WD, etc.
I’ve started to look at the price and what performance i get for it and it came down to synology and WD.
I decided to buy a WD MyCloud EX2 based on reviews, advertising and so on.
I’ve installed the WD NAS and immediately saw some things that i didn’t quite like or were under-developed for customer use. So i joined this forum and saw that there were alot of problems, the support was very limited so I got a little scared and decided that one WD EX2 was too unreliable for a stand alone device with my precious files. So i bought another EX2, the only purpose was backup for my primary NAS.
I gave suggestions to the support team, i also posted here some of them. I really liked WD and tried to give them the chance to improve, but even so, no firmware update since december 2014, no answer to the customers about their intentions or to tell the customers that they understand us and value our opinions here.
I am starting to regret that i didn’t spent the extra money on Synology and live happy like other user posted here. Is WD concerned about hte customers that they are loosing ?
The whole thing is so unreliable especially if you try to use it outside of your network. Only thanks to my whole network enviroment i manage to do some workarounds and make it work again.
the firmware is a joke and looks like it was done by some people that do not use a NAS on their own, or they haven’t seen what the competition offers.
So what i like about EX2:
fast read/write ( this is only because i don’t have another NAS to compare)
small and elegant design
quiet
apearently easy to use
intuitive explanations in the GUI
cheaper than other competitor ( now i know why
quality HDDs
So what i don’t like about EX2:
no power button. Even if WOL is available and something so simple as a power button may seem unnecessary, trust me it’s needed.
public folders can’t be made private ( on ex2100 it can, but firmware update for EX2 is 6 months old)
power scheduler is not customizable enough
smartphone apps are not reliable, maybe because of the ex2 's firmware. Sometimes it connects and the next time it sais that you don’t have access or permissions and you have to add the device again. Not reliable when you are away.
support is very limited
firmware is not customizable enough ( have you see Synology or Asustor ? …if not, take a good look you have enough to lean WD !! )
updates for EX2 stopped and no one from WD want to make an official statement about what’s going on.
backup works whenever it wants
unable to backup on a shared location except on another WD device
app market from ages ago with no active updating
for every new shared folder created, you have to create a separate backup job, because editing existing ones is impossible
no possibility to turn OFF .wdmc hidden folders where not needed. If you have to copy all the picture folders on another location, you will end up copying those hidden .wdmc folders aswell. If you have a few hundrets of picture folders, good luck clean that up.
When accessing EX2’s dashboard over internet or VPN, My cloud Services shows as turned OFF and can’t be turned on, but when i access the dashboard within the internal network, Cloud Services shows as ON. Also you can’t use tools that require Cloud Services to be turned ON, ex statistics of disk usage.
Dashboard can’t be accessed over VPN or any other subnet. The only workaround is to turn Cloud Access ON, even if you do not do the port forwarding on the router to actually have Cloud Access over the internet
FTP still has problems
If you have a normal backup job and you create a Sync backup job, it will not sync the existing backup, but it will create another folder and double your files on the backup target nas. Not to mantion that day 28 is the beste WD could do. What if i want to do a sync on day 30 or 31.
WOL is not a feature if the target is shutdown while attempting to run a backup job
no possibility to hide folders from users that do not have access
no idea is the fan is actually working or when it should be activated. Fan RPM is always 0
Like I saw a post here on the forum, what exactly did WD gave us here, some expensive HDD in a plastic box ???!! It’s not like WD is a new company that doesn’t have the money to pay some good programmers and to check out the competition. The wheel doesn’t have to be reinvented here WD, just do what others already made , but make it work.
Most likely in the near future, if WD continues like this, I will get rid of EX2s and buy a Synology.
