Mybook and WD TV PLAY, wont connect
Hello.
So i bought the WD TV PLAY today, and thought connecting would be easy…
after an hour, with searching forums for help, i havent gotten any farther…
My Mybook, is connected to a WNDR3700, and i want the WDTV, to use my harddrive as nas…
i have an boxee in the living room, which works fine, but the wdtv, only want to connect to my computer, and not the (nas) harddrive.
any1 have a solution? is it even possible ?
Basicly i want too stream from A - B
Is it a MyBook or MyBook Live.
You can ONLY connect through a DLNA media server, you CAN NOT connect the play to a network share (SMP/NFS).
