MyBook Live Duo Drives into EX4100
Hello to you all (first post) Apologies if I make this sound overly complicated!
I have just got an EX4100 with two 4TB drives en-route.
However I would like to remove the two 3TB (in Raid 1) populated drives out of MyBook live duo and install them into the EX4100.
Basically is this possible? I hoped it would be a simple as plug and play but after a quick test with them in the EX4100 it did detect them but could not see any data.
Any thoughts or suggestions are most welcome.
Thank you in advance,
Rory
I believe this is not possible. But I recommend you contact WD Support for more information.
https://support.wdc.com/support/case.aspx?lang=en
