MyBooklive Duo
I have reset, rebooted, unplugged -MybookLive Duo, modem and router yet I am unable to see/access the backup drive. I am not familiar with a lot of the lingo. If anyone can assist me??
Hi lubster,
The link below will allow you to call support.
Thanks. I did and they said they can’t help me that the unit is probably dead.
