Wie mounte ich die sda4 Partition korrekt im ssh terminal.
df
Filesystem 1K-blocks Used Available Use% Mounted on
rootfs 1968336 1709568 158780 92% /
/dev/root 1968336 1709568 158780 92% /
tmpfs 40960 3776 37184 10% /run
tmpfs 40960 64 40896 1% /run/lock
tmpfs 10240 0 10240 0% /dev
tmpfs 5120 0 5120 0% /run/shm
tmpfs 102400 1984 100416 2% /tmp
/dev/root 1968336 1709568 158780 92% /var/log.hdd
ramlog-tmpfs 40960 19008 21952 47% /var/log
wie soll ich die ordner richtig meinten
CacheVolume
DataVolume
shares
Mount -t ext4 /dev/sda4 /DataVolume scheint ja correct zu sein aber weder mit CacheVolume noch Shares komme ich zurecht
beim manuellem Firmware recovery versuch kommt folgende Fehlermeldung:
CrashCloud:/shares# /usr/local/sbin/updateFirmwareFromFile.sh /DataVolume/sq-040403-113-20160510.deb
updateFirmwareFromFile.sh:09/25/16 09:44:45:: ( /DataVolume/sq-040403-113-20160510.deb )
updateFirmwareFromFile.sh:09/25/16 09:44:45:upgrade start: /DataVolume/sq-040403-113-20160510.deb
updateFirmwareFromFile.sh:09/25/16 09:44:45:check_size=
/usr/local/sbin/updateFirmwareFromFile.sh: line 195: internalDrives: command not found
Error fw_update_status: failed 205 “all drives must be present for upgrade”
updateFirmwareFromFile.sh:09/25/16 09:44:45:failed 205 “all drives must be present for upgrade”
send_update_log=200
