N900 - iOS Wireless issues
I’m running into a really odd issue that I can’t figure out with this router.
iOS devices connect to the wifi and the browser works but applicaitons on the device do not send and receive data. I’ve verified it’s the wireless on this with another router that works perfect.
Things I’ve done to troublshoot it;
  1. Reset to factory.
  2. Turned off auto channel and set them manually.
  3. Attempted with DHCP assigned ip and reserved ip.
  4. Attempted with static ip vs dhcp
  5. Tested 2 different routers to verify device has no issue.
I’m stuck at this point, I’m unsure what step to try next I don’t have an ipad I can’t test. Right now I have an AP hooked up so I can use wifi off of it through PoE which is fine for the time being but I would think there has to be something else that can be done to get around this.
Hi, from the My net dashboard try to disable the Fastrack Check page 48 of the manual for more information.
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705072.pdf#page=52
So the Fastrack software seems to be the biggest culprit with everything yet it was one of the big pushes for the router. I assume that most likely won’t change since the line has been discontinued?
Thanks for the suggestion.
