My Log:
01/22 15:44:52 UPS-NAS02 daemon.info wixEvent[3452]: USB Status - USB device inserted.
01/22 15:44:00 UPS-NAS02 user.notice [5146]: disk at /devices/platform/oxnas-ehci.0/usb1/1-1/1-1:1.0/host2/target2:0:0/2:0:0:0
01/22 14:56:11 UPS-NAS02 daemon.warn wixEvent[3452]: Volume Status - Volume ‘DataVolume’ is resyncing, 0% had completed.
01/22 14:55:32 UPS-NAS02 daemon.info wixEvent[3452]: System Startup - System startup.
01/22 14:55:32 UPS-NAS02 daemon.warn wixEvent[3452]: System Abnormal Shutdown - System had abnormal shutdown last time.
01/22 14:55:30 UPS-NAS02 daemon.info init: Starting pid 3783, console /dev/ttyS0: ‘/sbin/getty’
01/22 14:55:29 UPS-NAS02 daemon.info init: Starting pid 3782, console /dev/null: ‘/bin/touch’
01/22 14:55:10 UPS-NAS02 syslog.info syslogd started: BusyBox v1.1.1
01/21 17:19:25 UPS-NAS02 daemon.warn wixEvent[3464]: Volume Status - Volume ‘DataVolume’ is resyncing, 65% had completed.
01/21 16:14:07 UPS-NAS02 daemon.warn wixEvent[3464]: Volume Status - Volume ‘DataVolume’ is resyncing, 44% had completed.
01/21 15:08:56 UPS-NAS02 daemon.warn wixEvent[3464]: Volume Status - Volume ‘DataVolume’ is resyncing, 23% had completed.
01/21 13:48:12 UPS-NAS02 daemon.info wixEvent[3464]: System Startup - System startup.
01/21 13:48:11 UPS-NAS02 daemon.warn wixEvent[3464]: System Abnormal Shutdown - System had abnormal shutdown last time.
01/21 13:48:10 UPS-NAS02 daemon.info init: Starting pid 3821, console /dev/ttyS0: ‘/sbin/getty’
01/21 13:48:10 UPS-NAS02 daemon.info init: Starting pid 3820, console /dev/null: ‘/bin/touch’
01/21 13:41:58 UPS-NAS02 daemon.warn wixEvent[3464]: Volume Status - Volume ‘DataVolume’ is resyncing, 0% had completed.
01/21 13:41:14 UPS-NAS02 syslog.info syslogd started: BusyBox v1.1.1
01/18 13:06:58 UPS-NAS02 daemon.warn wixEvent[3456]: Volume Status - Volume ‘DataVolume’ is resyncing, 64% had completed.
01/18 11:39:54 UPS-NAS02 daemon.warn wixEvent[3456]: Volume Status - Volume ‘DataVolume’ is resyncing, 42% had completed.
01/18 10:34:42 UPS-NAS02 daemon.warn wixEvent[3456]: Volume Status - Volume ‘DataVolume’ is resyncing, 21% had completed.
01/18 09:29:32 UPS-NAS02 daemon.warn wixEvent[3456]: Volume Status - Volume ‘DataVolume’ is resyncing, 0% had completed.
01/18 09:28:46 UPS-NAS02 daemon.info wixEvent[3456]: System Startup - System startup.
01/18 09:28:46 UPS-NAS02 daemon.warn wixEvent[3456]: System Abnormal Shutdown - System had abnormal shutdown last time.
01/18 09:28:44 UPS-NAS02 daemon.info init: Starting pid 3761, console /dev/ttyS0: ‘/sbin/getty’
01/18 09:28:44 UPS-NAS02 daemon.info init: Starting pid 3760, console /dev/null: ‘/bin/touch’
01/18 09:28:29 UPS-NAS02 syslog.info syslogd started: BusyBox v1.1.1
01/17 13:06:14 UPS-NAS02 daemon.warn wixEvent[3455]: Volume Status - Volume ‘DataVolume’ is resyncing, 63% had completed.
01/17 12:01:01 UPS-NAS02 daemon.warn wixEvent[3455]: Volume Status - Volume ‘DataVolume’ is resyncing, 43% had completed.
01/17 10:55:49 UPS-NAS02 daemon.warn wixEvent[3455]: Volume Status - Volume ‘DataVolume’ is resyncing, 22% had completed.
01/17 09:28:41 UPS-NAS02 daemon.warn wixEvent[3455]: Volume Status - Volume ‘DataVolume’ is resyncing, 0% had completed.
01/17 09:28:00 UPS-NAS02 daemon.info wixEvent[3455]: System Startup - System startup.
01/17 09:28:00 UPS-NAS02 daemon.warn wixEvent[3455]: System Abnormal Shutdown - System had abnormal shutdown last time.
01/17 09:27:57 UPS-NAS02 daemon.info init: Starting pid 3925, console /dev/ttyS0: ‘/sbin/getty’
01/17 09:27:57 UPS-NAS02 daemon.info init: Starting pid 3924, console /dev/null: ‘/bin/touch’
01/17 09:27:56 UPS-NAS02 daemon.err lld2d[3890]: osl_write_pidfile: /var/run/lld2d-eth0.pid contains pid 3878 which is still running; aborting
01/17 09:27:50 UPS-NAS02 daemon.info wixEvent[3455]: Network IP Address - NIC 1 use static IP address 192.168.1.200
01/17 09:27:50 UPS-NAS02 daemon.info wixEvent[3455]: Network Link - NIC 1 link is up 100 Mbps full duplex.
01/17 09:27:40 UPS-NAS02 syslog.info syslogd started: BusyBox v1.1.1
01/16 16:48:08 UPS-NAS02 daemon.warn wixEvent[3456]: Volume Status - Volume ‘DataVolume’ is resyncing, 68% had completed.
01/16 15:42:55 UPS-NAS02 daemon.warn wixEvent[3456]: Volume Status - Volume ‘DataVolume’ is resyncing, 47% had completed.
01/16 14:37:43 UPS-NAS02 daemon.warn wixEvent[3456]: Volume Status - Volume ‘DataVolume’ is resyncing, 26% had completed.
01/16 13:32:30 UPS-NAS02 daemon.warn wixEvent[3456]: Volume Status - Volume ‘DataVolume’ is resyncing, 6% had completed.
01/16 13:31:51 UPS-NAS02 daemon.info wixEvent[3456]: System Startup - System startup.
01/16 13:31:51 UPS-NAS02 daemon.info init: Starting pid 3913, console /dev/ttyS0: ‘/sbin/getty’
01/16 13:31:51 UPS-NAS02 daemon.info init: Starting pid 3912, console /dev/null: ‘/bin/touch’
01/16 13:31:38 UPS-NAS02 daemon.info wixEvent[3456]: Network IP Address - NIC 1 use static IP address 192.168.1.200
01/16 13:31:38 UPS-NAS02 daemon.info wixEvent[3456]: Network Link - NIC 1 link is up 100 Mbps full duplex.
01/16 13:31:29 UPS-NAS02 daemon.warn wixEvent[3456]: Network Link - NIC 1 link is down.
01/16 13:31:29 UPS-NAS02 syslog.info syslogd started: BusyBox v1.1.1
01/16 13:28:14 UPS-NAS02 syslog.info System log daemon exiting.
01/16 13:28:14 UPS-NAS02 daemon.info init: Starting pid 6349, console /dev/null: ‘/usr/bin/killall’
01/16 13:28:12 UPS-NAS02 daemon.warn wixEvent[3457]: System Reboot - System will reboot.
01/16 12:42:29 UPS-NAS02 daemon.warn wixEvent[3457]: Volume Status - Volume ‘DataVolume’ is resyncing, 0% had completed.
01/16 12:41:44 UPS-NAS02 daemon.info wixEvent[3457]: System Startup - System startup.
01/16 12:41:44 UPS-NAS02 daemon.warn wixEvent[3457]: System Abnormal Shutdown - System had abnormal shutdown last time.
01/16 12:41:43 UPS-NAS02 daemon.info init: Starting pid 3929, console /dev/ttyS0: ‘/sbin/getty’
01/16 12:41:43 UPS-NAS02 daemon.info init: Starting pid 3928, console /dev/null: ‘/bin/touch’
01/16 12:41:42 UPS-NAS02 daemon.err lld2d[3892]: osl_write_pidfile: /var/run/lld2d-eth0.pid contains pid 3891 which is still running; aborting
01/16 12:41:34 UPS-NAS02 daemon.info wixEvent[3457]: Network IP Address - NIC 1 use static IP address 192.168.1.200
01/16 12:41:34 UPS-NAS02 daemon.info wixEvent[3457]: Network Link - NIC 1 link is up 100 Mbps full duplex.
01/16 12:41:25 UPS-NAS02 syslog.info syslogd started: BusyBox v1.1.1
01/16 12:18:52 UPS-NAS02 daemon.warn wixEvent[3455]: System Reboot - System will reboot.
01/16 11:03:41 UPS-NAS02 daemon.warn wixEvent[3455]: Volume Status - Volume ‘DataVolume’ is resyncing, 20% had completed.
01/16 09:36:35 UPS-NAS02 daemon.warn wixEvent[3455]: Volume Status - Volume ‘DataVolume’ is resyncing, 0% had completed.
01/16 09:35:58 UPS-NAS02 daemon.info wixEvent[3455]: System Startup - System startup.
01/16 09:35:58 UPS-NAS02 daemon.warn wixEvent[3455]: System Abnormal Shutdown - System had abnormal shutdown last time.
01/16 09:35:56 UPS-NAS02 daemon.info init: Starting pid 3926, console /dev/ttyS0: ‘/sbin/getty’
01/16 09:35:56 UPS-NAS02 daemon.info init: Starting pid 3925, console /dev/null: ‘/bin/touch’
01/16 09:35:48 UPS-NAS02 daemon.info wixEvent[3455]: Network IP Address - NIC 1 use static IP address 192.168.1.200
01/16 09:35:47 UPS-NAS02 daemon.info wixEvent[3455]: Network Link - NIC 1 link is up 100 Mbps full duplex.
01/16 09:35:38 UPS-NAS02 syslog.info syslogd started: BusyBox v1.1.1
01/15 18:52:01 UPS-NAS02 daemon.warn wixEvent[3453]: Volume Status - Volume ‘DataVolume’ is resyncing, 69% had completed.
01/15 16:41:31 UPS-NAS02 daemon.warn wixEvent[3453]: Volume Status - Volume ‘DataVolume’ is resyncing, 43% had completed.
01/15 15:14:23 UPS-NAS02 daemon.warn wixEvent[3453]: Volume Status - Volume ‘DataVolume’ is resyncing, 21% had completed.
01/15 14:09:10 UPS-NAS02 daemon.warn wixEvent[3453]: Volume Status - Volume ‘DataVolume’ is resyncing, 0% had completed.
01/15 14:08:31 UPS-NAS02 daemon.info wixEvent[3453]: System Startup - System startup.
01/15 14:08:31 UPS-NAS02 daemon.warn wixEvent[3453]: System Abnormal Shutdown - System had abnormal shutdown last time.
01/15 14:08:30 UPS-NAS02 daemon.info init: Starting pid 3927, console /dev/ttyS0: ‘/sbin/getty’
01/15 14:08:30 UPS-NAS02 daemon.info init: Starting pid 3924, console /dev/null: ‘/bin/touch’
01/15 14:08:29 UPS-NAS02 daemon.err lld2d[3888]: osl_write_pidfile: /var/run/lld2d-eth0.pid contains pid 3888 which is still running; aborting
01/15 14:08:21 UPS-NAS02 daemon.info wixEvent[3453]: Network IP Address - NIC 1 use static IP address 192.168.1.200
01/15 14:08:21 UPS-NAS02 daemon.info wixEvent[3453]: Network Link - NIC 1 link is up 100 Mbps full duplex.
01/15 14:08:10 UPS-NAS02 syslog.info syslogd started: BusyBox v1.1.1
01/11 06:39:01 UPS-NAS02 daemon.warn wixEvent[3451]: Volume Status - Volume ‘DataVolume’ is resyncing, 68% had completed.
01/11 05:12:05 UPS-NAS02 daemon.warn wixEvent[3451]: Volume Status - Volume ‘DataVolume’ is resyncing, 43% had completed.
01/11 04:06:53 UPS-NAS02 daemon.warn wixEvent[3451]: Volume Status - Volume ‘DataVolume’ is resyncing, 22% had completed.
01/11 02:39:44 UPS-NAS02 daemon.warn wixEvent[3451]: Volume Status - Volume ‘DataVolume’ is resyncing, 0% had completed.
01/11 02:39:05 UPS-NAS02 daemon.info wixEvent[3451]: System Startup - System startup.
01/11 02:39:05 UPS-NAS02 daemon.warn wixEvent[3451]: System Abnormal Shutdown - System had abnormal shutdown last time.
01/11 02:39:02 UPS-NAS02 daemon.info init: Starting pid 3923, console /dev/ttyS0: ‘/sbin/getty’
01/11 02:39:02 UPS-NAS02 daemon.info init: Starting pid 3922, console /dev/null: ‘/bin/touch’
01/11 02:38:53 UPS-NAS02 daemon.info wixEvent[3451]: Network IP Address - NIC 1 use static IP address 192.168.1.200
01/11 02:38:53 UPS-NAS02 daemon.info wixEvent[3451]: Network Link - NIC 1 link is up 100 Mbps full duplex.
01/11 02:38:44 UPS-NAS02 syslog.info syslogd started: BusyBox v1.1.1
01/11 01:15:14 UPS-NAS02 daemon.warn wixEvent[3457]: Volume Status - Volume ‘DataVolume’ is resyncing, 65% had completed.
01/10 23:48:05 UPS-NAS02 daemon.warn wixEvent[3457]: Volume Status - Volume ‘DataVolume’ is resyncing, 42% had completed.
01/10 22:42:53 UPS-NAS02 daemon.warn wixEvent[3457]: Volume Status - Volume ‘DataVolume’ is resyncing, 21% had completed.
01/10 21:37:41 UPS-NAS02 daemon.warn wixEvent[3457]: Volume Status - Volume ‘DataVolume’ is resyncing, 0% had completed.
01/10 21:37:02 UPS-NAS02 daemon.info wixEvent[3457]: System Startup - System startup.
01/10 21:37:02 UPS-NAS02 daemon.warn wixEvent[3457]: System Abnormal Shutdown - System had abnormal shutdown last time.
01/10 21:37:00 UPS-NAS02 daemon.info init: Starting pid 3924, console /dev/ttyS0: ‘/sbin/getty’
01/10 21:37:00 UPS-NAS02 daemon.info init: Starting pid 3923, console /dev/null: ‘/bin/touch’
01/10 21:36:52 UPS-NAS02 daemon.info wixEvent[3457]: Network IP Address - NIC 1 use static IP address 192.168.1.200
01/10 21:36:52 UPS-NAS02 daemon.info wixEvent[3457]: Network Link - NIC 1 link is up 100 Mbps full duplex.
01/10 21:36:41 UPS-NAS02 syslog.info syslogd started: BusyBox v1.1.1
01/10 20:33:57 UPS-NAS02 daemon.warn wixEvent[3463]: Volume Status - Volume ‘DataVolume’ is resyncing, 69% had completed.
01/10 19:28:45 UPS-NAS02 daemon.warn wixEvent[3463]: Volume Status - Volume ‘DataVolume’ is resyncing, 48% had completed.
01/10 18:01:37 UPS-NAS02 daemon.warn wixEvent[3463]: Volume Status - Volume ‘DataVolume’ is resyncing, 25% had completed.
01/10 16:34:41 UPS-NAS02 daemon.warn wixEvent[3463]: Volume Status - Volume ‘DataVolume’ is resyncing, 0% had completed.
01/10 16:34:00 UPS-NAS02 daemon.info wixEvent[3463]: System Startup - System startup.
01/10 16:34:00 UPS-NAS02 daemon.warn wixEvent[3463]: System Abnormal Shutdown - System had abnormal shutdown last time.
01/10 16:33:58 UPS-NAS02 daemon.info init: Starting pid 3925, console /dev/ttyS0: ‘/sbin/getty’
01/10 16:33:58 UPS-NAS02 daemon.info init: Starting pid 3924, console /dev/null: ‘/bin/touch’
01/10 16:33:57 UPS-NAS02 daemon.err lld2d[3887]: osl_write_pidfile: /var/run/lld2d-eth0.pid contains pid 3887 which is still running; aborting
01/10 16:33:52 UPS-NAS02 daemon.info wixEvent[3463]: Network IP Address - NIC 1 use static IP address 192.168.1.200
01/10 16:33:52 UPS-NAS02 daemon.info wixEvent[3463]: Network Link - NIC 1 link is up 100 Mbps full duplex.
01/10 16:33:42 UPS-NAS02 daemon.warn wixEvent[3463]: Network Link - NIC 1 link is down.
01/10 16:33:41 UPS-NAS02 syslog.info syslogd started: BusyBox v1.1.1
01/10 11:03:12 UPS-NAS02 daemon.warn wixEvent[3454]: Volume Status - Volume ‘DataVolume’ is resyncing, 64% had completed.
01/10 09:58:01 UPS-NAS02 daemon.warn wixEvent[3454]: Volume Status - Volume ‘DataVolume’ is resyncing, 43% had completed.
01/10 08:52:49 UPS-NAS02 daemon.warn wixEvent[3454]: Volume Status - Volume ‘DataVolume’ is resyncing, 22% had completed.
01/10 07:25:44 UPS-NAS02 daemon.warn wixEvent[3454]: Volume Status - Volume ‘DataVolume’ is resyncing, 0% had completed.
01/10 07:25:06 UPS-NAS02 daemon.info wixEvent[3454]: System Startup - System startup.
01/10 07:25:06 UPS-NAS02 daemon.warn wixEvent[3454]: System Abnormal Shutdown - System had abnormal shutdown last time.
01/10 07:25:05 UPS-NAS02 daemon.info init: Starting pid 3946, console /dev/ttyS0: ‘/sbin/getty’
01/10 07:25:05 UPS-NAS02 daemon.info init: Starting pid 3944, console /dev/null: ‘/bin/touch’
01/10 07:24:55 UPS-NAS02 daemon.info wixEvent[3454]: Network IP Address - NIC 1 use static IP address 192.168.1.200
01/10 07:24:55 UPS-NAS02 daemon.info wixEvent[3454]: Network Link - NIC 1 link is up 100 Mbps full duplex.
01/10 07:24:43 UPS-NAS02 syslog.info syslogd started: BusyBox v1.1.1
01/10 06:53:57 UPS-NAS02 daemon.warn wixEvent[3457]: Volume Status - Volume ‘DataVolume’ is resyncing, 63% had completed.
01/10 05:48:43 UPS-NAS02 daemon.warn wixEvent[3457]: Volume Status - Volume ‘DataVolume’ is resyncing, 43% had completed.
01/10 04:21:45 UPS-NAS02 daemon.warn wixEvent[3457]: Volume Status - Volume ‘DataVolume’ is resyncing, 22% had completed.
01/10 02:54:37 UPS-NAS02 daemon.warn wixEvent[3457]: Volume Status - Volume ‘DataVolume’ is resyncing, 0% had completed.
01/10 02:53:53 UPS-NAS02 daemon.info wixEvent[3457]: System Startup - System startup.
01/10 02:53:53 UPS-NAS02 daemon.warn wixEvent[3457]: System Abnormal Shutdown - System had abnormal shutdown last time.
01/10 02:53:51 UPS-NAS02 daemon.info init: Starting pid 3927, console /dev/ttyS0: ‘/sbin/getty’
01/10 02:53:51 UPS-NAS02 daemon.info init: Starting pid 3926, console /dev/null: ‘/bin/touch’
01/10 02:53:43 UPS-NAS02 daemon.info wixEvent[3457]: Network IP Address - NIC 1 use static IP address 192.168.1.200
01/10 02:53:43 UPS-NAS02 daemon.info wixEvent[3457]: Network Link - NIC 1 link is up 100 Mbps full duplex.
01/10 02:53:35 UPS-NAS02 syslog.info syslogd started: BusyBox v1.1.1
01/09 22:46:24 UPS-NAS02 daemon.warn wixEvent[3458]: Volume Status - Volume ‘DataVolume’ is resyncing, 45% had completed.
01/09 20:57:44 UPS-NAS02 daemon.warn wixEvent[3458]: Volume Status - Volume ‘DataVolume’ is resyncing, 21% had completed.
01/09 19:52:31 UPS-NAS02 daemon.warn wixEvent[3458]: Volume Status - Volume ‘DataVolume’ is resyncing, 0% had completed.
01/09 19:51:51 UPS-NAS02 daemon.info wixEvent[3458]: System Startup - System startup.
01/09 19:51:50 UPS-NAS02 daemon.warn wixEvent[3458]: System Abnormal Shutdown - System had abnormal shutdown last time.
01/09 19:51:50 UPS-NAS02 daemon.info init: Starting pid 3769, console /dev/ttyS0: ‘/sbin/getty’
01/09 19:51:49 UPS-NAS02 daemon.info init: Starting pid 3768, console /dev/null: ‘/bin/touch’
01/09 19:51:47 UPS-NAS02 daemon.err lld2d[3723]: osl_write_pidfile: /var/run/lld2d-eth0.pid contains pid 3723 which is still running; aborting
01/09 19:51:30 UPS-NAS02 syslog.info syslogd started: BusyBox v1.1.1
01/09 18:53:55 UPS-NAS02 daemon.warn wixEvent[3452]: Volume Status - Volume ‘DataVolume’ is resyncing, 62% had completed.
01/09 17:48:43 UPS-NAS02 daemon.warn wixEvent[3452]: Volume Status - Volume ‘DataVolume’ is resyncing, 42% had completed.
01/09 16:43:31 UPS-NAS02 daemon.warn wixEvent[3452]: Volume Status - Volume ‘DataVolume’ is resyncing, 21% had completed.
01/09 15:38:17 UPS-NAS02 daemon.warn wixEvent[3452]: Volume Status - Volume ‘DataVolume’ is resyncing, 0% had completed.
01/09 15:37:33 UPS-NAS02 daemon.info wixEvent[3452]: System Startup - System startup.
01/09 15:37:33 UPS-NAS02 daemon.warn wixEvent[3452]: System Abnormal Shutdown - System had abnormal shutdown last time.
