Need help recovering files/folders from My Book Live Duo
2018-04-26 - I installed a My Book Live Duo (2 x 2TB; RAID 1) in a client’s site back in May 2013 to be used as a file server. It was ready to go and I installed nothing. Connected to a LAN which all office staff accessed. It worked beautifully until now. All the client’s PCs and laptops are Win 7 and the server is Windows SBS 2011. Clicking shortcuts to folders within gets an error pop-up box. The server can access the drive and some but not all the folders are there. The folders are all grayed out and clicking any one gets a pop-up error message.
The unit’s LED was RED. Un-plug, wait and re-plug the power turns the LED to Blue, then Yellow (stays yellow for a few minutes), then Red.
Brought the unit home and plugged it into my home network and the same results. While the light is yellow, I can hear sounds of wanting to start-up.
Brought the unit to a computer shop. The tech guy pulled the HDD out and connected those into his Windows 10 computer. One drive is bad and the other is still good. I can see the partitions and they are all healthy. I asked him to look into the folders and he cannot read anything of the good drive. It seems Windows 10 does not recognize its format.
I brought the unit home and tried to start it with just the good drive and got the same red light after blue and yellow.
The reason I got a mirrored drive is so that if one drive is bad, the other one can continue and I can at least extract data to be transferred to another unit. I’ve had failed RAID 1 drives in the past (internal to the server) and have always been able to transfer data to another device, until now. What good is the good drive if I can’t read it?
Can someone out there help me with this? My client does not mind buying new hardware but the data is irreplaceable.
Hi Tumbelina,
The link below will allow you to call support.
2018-05-01 Brandon.P, Thank you for your suggestion.
Yesterday morning, I brought the unit to a WD service centre called ‘Ontrack’.
Surprise, they are only 3 km from my house.
I’ll find out in a day or 2 what can be done.
Correct me if I am wrong:
I think there is a RAID controller inside the unit and it is dead.
To complicate matters, the controller has a hold on the HD.
Maybe, the bad HD died sometime ago and nobody noticed but that should
not have prevented the unit from functioning despite its demise.
I looked for jumper switches on the drive, like the old Master/Slave
technology to somehow free the HD from the RAID but there is none.
