Hi everyone,
Now the WD My Passport Ultra that I own is from 2014 and today I opened it the first time to realize that it is not compatible with my MacBook Pro (which is updated to Yosemite)! Or at least I think…
If I go to Disk Utility and try to reformat it from Windows to Mac (as I have seen on tutorials and the help portals) it simply won’t work and a new error always appears.
PLEASE look at the images to see my problem:
and
As you see when I highlight the “2 TB WD My Passport…” thing and try to convert it from MS-DOS (FAT) to MAC OS Extended (journaled) a DISK ERASE error comes up. If I highlight the partition and go to Erase the format: Windows NT File System is, not only, grey as if I wouldn’t be able to change anything, it also, doesn’t let me format it to MAC OS Extended (journaled) and instead a VOLUME ERASE error comes up.
I have seen on some help websites that you can go to partition and do something there that apparently should help and solve the error, BUT I also followed those steps and still nothing has changed.
I need to know from all of you helpful mates out there if I should give up and realize I have bought the wrong thing and go cry or if I should try something else that will actually work- something you guys recommend!
THANKS in advance,
