Need replacement options for "WDTV Live Hub Media Center"
Need replacement options for “WDTV Live Hub Media Center”…
Need some options that are newer products that can do the same functions as the “WDTV Live Hub Media Center”
https://support.wdc.com/product.aspx?ID=1010&lang=en
Buy something that supports Kodi (formerly XBMC)
which is infinitely better media software with the same functions plus lots more !
Plenty of Hardware options, start reading here: START HERE - Pick the Right Kodi Box (updated Dec 2020)
personally speaking, i replaced my Live Hub with a Raspberry Pi 3 … have had it since Feb 2016 and before that, a RPi2 for over a year, couldn’t be happier with my Pi :slight_smile:
I agree. I am using a MINIX NEO X8-H, running XBMC, but a warning - the ability of copying videos’ to a locally connected drive on an android device is not simple and is best avoided. You may be better off running a NAS (WD My Cloud) with your content on it and using smb from your android media server to play the video. If you do not have a NAS, using your old WDTV as a smb server i a viable option.
