Netflix not loading up
The Netflix app just hangs indefinantly.
I have used it before during the 30 dy trial about 6 months ago an today I subscribed thinking it would work again as it did before.
I did a quick search but nothing is recent and relevent to my problem.
Using atest firmware accoring to th WDTV live thing 1.151.0
Works on my PC no problems.
Hello, disconnect the WDTV from power for 20 seconds and then try again, if the problem continues, you can also try pressing the reset button on the bottom side for 1 second.
