Network sharing folders showing issue
I have set my WD to sdhow the network shares.
I have various folders, but mainly 3. Film, Music, Photos
Now when I go into pictures, all those folders are showing up… Is there a way to only show the folders wich contain the right formats for playing?
Cause when I go into movies, or pictures all my folders are showing, but off course, not all contain those items…
thx
There is, but its more of a fudge really.
So you are using Network Shares to look at videos etc, not the Files menu.
There are a couple of options if you are.
Setup/Options/System/Media Library - Clear Media Library (does not touch files, but rebuilds the Library)
Or Power down by holding the Power button >5 secs, then power up again.
That should sort it.
