When I firts used my Hub, I just wanted to use a Shared Network (My own NAS). I did not really know the functions of the hub so I had also performed a network_sync… I did not realize that all my files from my NAS were going to be duplicated on the internal hard drive of the hub doing so. I did not need that at all.
Now, I turned the network_sync off but the hard disk space shows that I only have 500GB left! I should have almost the full drive hard disk space available since I’m not using the network_sync anymore. I looked in the hub files with my PC and there is no folder or files at all under the network_sync folder. Windows Explorer is set to display hidden files as well.
I also found out something strange when I was playing a bit with the web interface wonky server. I found out that the files used previously in the network_sync were still there in the share option! How come I can see these files there but not in Windows Explorer! There is my used space! I tried to delete the share in the Twoky server and doing so managed to display 0 files under Media on Twonky but my space was not recovered anyway.
From there I don’t know what to do in order to recover my hard disk space in the Hub internal drive. I read some posts about reformatting issues so I don’t ant to go there…
