I’ve had a WD HD media player for a few months now. It worked fine, it connected to my wifi perfect. This past month it suddenly wont connect to my wifi.
Any idea what could be going on?
Hi, I have the same issue. My WD TV Live Hub worked fine till now with the WiFi…Now it doesn´t find anything with the automatic mode (will find the SSID) only the wired connection works. Something to do with automatic updates? I put off the Firewall from the modem and no help either. It will find the IP address and mask if put manually but the dns doesn´t match…
I dont have that problem.
When I automatically connect it says limited or no connectivity from the IP address
When I connect manually it says set up complete but the wifi still doesnt work.
Anyone know what Im doing wrong?
