Hi all,
I just bought a new WD blue 1TB hard drive and it shows as 33mb … i can not allocate and the threads on the internet all point to old links … or old programs to fix this… should i just return the HD or can anyone help me please?
Thanks in advance.
Hi Siri,
May be you should try contacting WD’s Technical Support about this.
The link below will allow you to call support.
Hi Brandon,
Thanks for the answer.
I just returned the HD and used a 500GB (2nd hand).
