New System Installation Difficulties
I bought a live hub and installed it on a wired home network. I have several questions:
I have the Live Hub HDMI output connected to one of the HDMI inputs to my receiver (Pioneer VSX1020). I also have the analog output wired to a multiplexer so that the signal can be distributed on the house cable system as a TV channel. When I play a file on the hub with the receiver set to that HDMI line, the signal indeed shows up on my house cable system. This works fine as long as the receiver is accepting the HDMI input from the live hub.  It seems that when I switch the receiver to some other input while the live hub is playing a file, it will no longer produce a decent analog video output on the cable network (there is a very noisy image of the menu).  Is this a remedial condition or a fault?
When I first powered up the unit, I did not have the video outputs connected.  I loaded the live hub with some forty CDs. They played back over the Ethernet cable on my computer just fine.  Then, I brought up the video side of the system.  Now that I had a screen attached to the Live Hub, I installed the new firmware. OOPS!  The server still plays the music just fine on my receiver over the HDMI line.  However, after installing the firmware, my computer would no longer play the files I had uploaded over the Ethernet.  I get a message indicating an unknown file extension.  These were ripped as mp3 files.
To see if the extension had been added, I  then ripped a new CD to the live hub and was able to play it back over the Ethernet just fine. The older files still showed the problem but still show themselves to be ,mp3 files. Huh?
Final question: When I power down the rack, it kills the live hub instantly.  Am I correct that I should be shutting down the live hub before powering down the system so that it can park the head?
As to wishes, I REALLY wish that WD sold this unit with TWO drives that I could run at RAID1.  I hate the idea of spending all the time to rip a half-TB CD and DVD collection only to have it disappear because there isn’t a backup drive in the unit (see above).  I would gladly have spent the extra hundred bucks or so to have had a RAID1 backup drive.  WHY NOT??? Isn’t WD in the business of selling disk drives???  C’mon!!!
Thanks,
M
Thanks,
M
The Live Hub is a media player with a built-in hard disk. It is designed to play media files from the internal disk and stream files to other media devices. The hardware will do this fairly successfully. At best the Hub is a very basic NAS. That is not the primary purpose of the Hub. I think that because the Hub has an internal disk and a network interface a lot of people think that they can use it in place of a proper NAS. If you want a NAS with RAID buy a proper NAS box and backup your stuff and the Hubs disk to that. The Hub hardware will never be able to run a proper NAS, let alone a RAID.
Thank you for your reply.
I already have a NAS drive elsewhere on the network set to RAID1.
What I wanted on the Live Hub was to keep a library of media and entertainment files, for which it was designed.
It takes approximately a week of my time to load all that material onto the drive (particularly old VHS tapes).
That time is valuable. I want a backup drive to protect that time investment.
Yes transferring stuff to the Hub is pretty slow, that’s why it’s not a good idea to use it as a NAS. Better to use your real NAS to backup the Hubs content.
Well, the HUB was not designed to be a NAS or as a backup for media.  It’s designed to be a MEDIA PLAYER with a internal drive only.
If keeping a backup of you media is what you want, then what you need to do is to get a USB external drive, place your media on it, then plug it into the HUB and use the Sync function to sync the external drive to the internal drive.
Again, I am not using the Live Hub as a NAS, I already have a 4TB Buffalo NAS drive.
I am still waiting to find out why updating the firmware on my LiveHub made the mp3 flies I had previously loaded unplayable on every computer in the network other than the LiveHub itself.  Until I had updated the firmware, everything was working firne.  Now, Windows Media Player on my computer reports that the file extension is not recognizeable.
The time it took to rip the CDs and load those files was worth more than the unit.
I am still waiting to find out why switching my receiver away from the LiveHub HDMI input wrecks the analog video output. It means that people using the LiveHub elsewhere on the network will get a rotten signal unless the system is playing the same thing in the living room. That makes no sense for a network server.
These two faults, plus the non-response I’ve received from the WD people I KNOW are lurking here, means the LiveHub gets a stinging two-star review on Amazon unless I get answers. I understand that such things can be hard to find and take time. I just want to know that SOMEBODY understands and is addressing these problems. If you want clarification on the exact sequence of events and system configuration, I can do that. In posting here I was hoping that somebody knew about and could report on these conditions.
Instead of answers or even a “please wait, we’re working on that” I got a bunch of noise about how it isn’t a NAS drive. I already knew that it isn’t a NAS drive. I ALREADY HAD A NAS DRIVE. I was suggesting that you offer a RAID1 unit because I would have bought one so that expensive events like wiping out my files with a firmware upgrade would not happen.
I hope that’s clear now. Thanks.
Well, first, this is a USER forum, this is not the place to interact with WD staff and they only respond to posts when they feel it necessary to make a clarification.
Second, what you are trying to do is not what the HUB is designed for. It is only designed to be a single output device, meaning that you connect it to a singe system.  It is not meant to be a multi-room device, nor to output both through the HDMI and analog at the same time.  If you want to have multi-room viewing, then you need to use secondary components for that.
Third, the reason people are telling you that this is not a NAS, is because you keep refering to it as network server and asking why it couldn’t be a Raid1.  It is not a network server and the reason it’s not  a Raid1 is because it wasn’t designed to be.  The HUB is basically a media streamer with a internal HDD, nothing more, and this is what it was designed for.  That it can work to some extent as a network server does not mean that it was designed to be, end of story.  If you need backups of your files, then you need to use your Raid1 for that.
Forth, if you are having problems with playing MP3’s then try roling back the firmware, you can find info on that HERE.
Are you trying to play the mp3 files from the Hub as a mapped drive or is Windows Media Player playing the files via the Hubs media server?
You have the Hubs HDMI output connected to a receiver and the Hubs component or composite output to a cable box? I have never tried to connect more than one video output, but I’ve read that it’s not possible.
If you want to get help from WD you need to contact them via http://support.wdc.com/contact/
This forum is for user to user support. The WD staff usually just monitor the forum to make sure that everybody is following the forum rules.
You can make a suggestion to include RAID1 in the ideas forum.
Just go ahead and post your two star review, I 'm sure that WD won’t lose sleep and I would certainly assume that they don’t respond to threats. If you read any reviews on the internet you will see they are full of negative points but that does not stop most people buying the product. I would have never purchased anything if I took any notice of reviews.
Just had another thought, when you switch the receiver away from the Hubs HDMI input, have you tried going into the Hubs setup and change the video output to component or composite. The Hub may not be switching automatically from HDMI to analogue.
First, I apologize for taking so long to reply. I wrote a lengthy response to your post, but it was dropped when I executed a “back” command on the browser and it overshot the editing page and wiped out my work. I had run out of time. So this is a reconstruction of that post with some additional information.
I am a USER. I had installation problems that I perceived (it turns out, correctly) were due to a combination of software changes, machine malfunctions, and design limitations. I came here and asked for help. I also made suggestions as to the latter. If the WD staff chose not to help, then they should have told me where to find it and not just give me silence. Silence is totally unprofessional.
I bought the Live Hub to play my music and video ripped from my CDs, DVDs, and VHS tapes. The Live Hub has a 1TB drive; that means it has the capacity to store my media collection. The Live Hub has an Ethernet connection; that means I can (and should be able to) rip mp3 and mp4 files from my own CDs, DVDs, and tapes store them on the Live Hub as the destination drive.  I should then be able to stream them back to my computer using Windows Media Player or the equivalent from any computer on my home over the Ethernet connection provided. That way I could stream all my media from one player and empty the shelves in my office bookshelves of bulky storage media in order to use them for books. I started doing just that with some mp3 files, and it worked just fine, that is, until I upgraded the firmware.
I had spent some 6 hours intermittently ripping some 60 CDs and storing them on the Live Hub. The Live Hub performed said playback function flawlessly, streaming the music to my computer. Then, after the firmware upgrade, the only output that worked was the HDMI. I could no longer access my files and to stream them to my house Ethernet network via the Live Hub Ethernet connection. The only Live Hub output from which I could play them was using the HDMI output directly into the receiver. Hence my complaint about the firmware upgrade and my question as to whether the outcome was intentional.
It has an Ethernet connection, I should be able to stream those media files to any computer in my house unless WD has deliberately made them inaccessible for any playback other than the HDMI. That is what the firmware upgrade did. OK, that’s the Ethernet/firmware problem; now, on to the video problem.
Interestingly, what you say the Live Hub cannot do is the ONLY thing it would do. The only time the analog output would work is if the receiver HDMI input was selecting the Live Hub HDMI output. If I switched the receiver to a DVD player (for example) while the Live Hub was playing, then the Live Hub ANALOG video output went loopy (vertical hold problems in monochrome).
I have the necessary secondary components to distribute analog video in my home. The analog video output goes to a multiplexer/signal-amplifier which puts the video signal from the Live Hub on analog TV channel 114. The multiplexer  sends that output back via coaxial cable to my video distribution panel. There, a splitter/combiner adds channel 114 to the coax cable network. That signal then gets split to be distributed throughout the house on coaxial cable. NONE of that system demands more than an analog signal from the yellow RCA jack capable of supplying a single television, which the Live Hub is designed to provide. Now, when I had the receiver looking at the Live Hub HDMI, an analog TV hooked to said coaxial network showed the Live Hub output on channel 114.  Meanwhile my digital monitor also showed the Live Hub HDMI output.  Both outputs were working at the same time, which you say is impossible.
I plan to replace the analog TV in the room with a big screen receiving the HDMI output from the receiver. To accomplish having two digital screens on one receiver, I plan to split the HDMI receiver output to a second digital monitor in the rack with the receiver and the Live Hub. The reason I have the rack monitor is that rack is located in a spot from which it will be difficult to see the big screen while using a USB keyboard connected to the Live Hub  (for which the Live Hub was supposedly designed). Hence, I will split the HDMI output from the receiver, sending one leg to the monitor on the rack and the other to the big screen (I have the HDMI splitter/amplifier). All of that is downstream of the receiver which is downstream from the Live Hub; so splitting the output should not affect the Live Hub. Yes, I have tried removing the splitter/amplifier from the circuit to no avail. All the cables are of better than average quality.
As I said above, the only time the yellow RCA analog video output worked was when the receiver was switched to receive the Live Hub HDMI output. So, to see if the Live Hub would play the RCA analog output alone, I disconnected the HDMI cable from the Live Hub and set the Live Hub’s yellow analog video into the same video network that works perfectly when fed from a DVD player.  When I fired the system up the video image was still bad.  Hence, my suspicion that the Live Hub was defective, but I came here to ask the question. Fortunately (in some respects), both the HDMI and the analog video output have since died completely and I sent it back.
As I have told all of them, I have a separate NAS drive for data on the Ethernet network. It is Raid1. This house has TWO networks : analog coaxial cable and Cat-5e Ethernet cable combined into structured cable throughout the house. The panel switches sixteen Cat-5e lines, while the analog panel has the capacity to process sixteen coaxial lines.
I knew that. The point about Raid1 was simply that I would like WD to make such a product. Is that so hard to understand?
I was streaming media files via the Ethernet cable. I want to use the Live Hub as a player on EITHER, the Ethernet cable, the HDMI, or the video cable. I am not trying to send files over the Ethernet to more than one computer at a time. I do not need to have the Live Hub play on more than one output at a time. I am not sending anything out of the house in such a manner as would violate anybody’s intellectual property. What you say it was designed to do is what I want to do with it.
Yet the one and ONLY thing the Live Hub does do (or did, until it died completely) is play video on two outputs simultaneously (the HDMI and the yellow RCA analog output), which is what you say it was NOT designed to do. So your implication that I am somehow ignorant or asking too much of the player is incorrect. I simply want to play files out of the HDMI or the video output, or stream files through the Ethernet Cat-5e cable, all of which the unit is at least physically capable of doing by specification; else it is defective. To have video on both HDMI and video simultaneously was a nicety I had hoped to derive for diagnostic purposes as well as for the purposes of playing the output in other rooms should someone be bedridden and want to watch a movie, but I can do well enough without it for now. At the time I was using it I had not yet installed the big screen HDTV, in part because the HDMI from the Live Hub was so unstable.
So yes, I have requested an RMA and have received the replacement unit under warranty.
Finally, here is why I want WD to make a Raid1 Live Hub : If I rip all those CDs, DVDs, and VHS files onto my player so that I can play them back, it will take WEEKS to load, rip, unload, store, and organize the files. Weeks of time are expensive (even while multi-tasking). Raid1 would offer added security to reduce the risk to that investment for which I am willing to pay. So, while I was trying to solve those other problems with my original post, I was trying to be helpful, suggesting that WD make said better product so that they could sell more drives. Yet until your post, all I have received in feedback is that it isn’t a NAS drive.
WD makes drives. WD makes media players. That means WD (supposedly) wants to sell drives that play media. I want to buy drives that play media. So, I tried to tell WD that I want WD to make a Raid1 Live Hub with (replaceable drives and rack mountable, please). That way, they would get to sell TWICE as many drives in each Live Hub. I thought WD marketing people would like to know that somebody wants to buy more drives and thought that WD staff, seeing such a message, would obviously want to help their company by emailing the request to WD marketing staff. Not only do I want a better product, I wanted to help WD because I once knew good people who (hopefully still) work there.
Sadly, if what I’ve seen here is common at WD, his job may be in jeopardy.
I already planned to buy a USB drive for backup purposes. I will leave it disconnected most of the time to assure that it remains uncorrupted.  I was going to purchase it once I had the video and music files loaded into the drive.
This is the first substantive answer I have received for all this frustration. Thank you.
After installing the firmware update did you reset the hub ?
Yes
I don’t think the Hub was switching at all.  The composite output was always on, if not always readable.
I am feeding the receiver from three devices: a DVD player, a VHS player, and the Live Hub. The other two devices have multiple outputs such that they can feed both the receiver and the multiplexer, so there’s no problem there.  Given that the Hub’s HDMI output alone goes through the receiver and then to the HD screens (similar to a BlueRay player), while the analog composite output goes directly to the multiplexer and then to a CRT TV, how would I see the menu when I switch the receiver input away from the Hub output unless it was on the analog side?
I would have assumed that, given that digital and analog outputs are driven totally differently and the power levels are so low, there would be no such need to turn one or the other off. I could see the need for the receiver to sink to zero the HDMI inputs it is not using to preclude reflections from being read as signals by devices on the supply side, but I don’t know enough about the communications protocol in HDMI to guess as to how that is managed.
Codgertator:
When you switch off HDMI, does the Hub go to Compostite(PAL) or Composite(NTSC)?   It sounds like it might be set to the wrong thing (you mentioned monochrome / out of sync video hold… exactly the symptoms.)
If it’s defaulting to the wrong one, you may need to do the 10-SECOND reset to change the NTSC/PAL mode in hardware.
Second, there is definitely a bug in the Hub and SMP that if you move from HDMI to COMPOSITE, the analog AUDIO may not function unless you manually reset the audio to STEREO.  Even if it’s already set to STEREO, you may need to do it AGAIN to “wake up” the outputs.
You want 2 hard drives in the WDTV Live Hub? WD has not even fixed DVD and BD menu issues, Audio issues, Video isssues, Reliability issues, you are gonna spend more money at the Wishing Well than getting your self a few hard drives and making your own RAID nas box. Have you looked around the forum? WD isn’t bothering to fix simple issues, they break something new in every new firmware, attempting to provide more eye candy with the newest “App” bcause everyone wants to jump on the app wagon. Funny, I don’t recall anyone using the word App before the iPhone. You can thank Apple for that. WD is trying to run fast to catch up on the netflix money, good luck RAIDING on that.
I think you may find that WD don’t call it an ‘app’ they call it a ‘service’. Carry on camping.
