Last week a WD tech support told me that the WD My cloud 4TB support NFS, I just bought one and update the firmware to: WDMyCloud v04.01.03-421 : Core F/W
somehow, I can not find NFS setting in anywhere. can someone give some ideas where is the startup point? or any document for that. I want to use it as a ESXi storage
thanks
usera
By the way, did searth forum, look like it support the NFS, but need to do some lower level setup, where can i found that information?
depending on your Windows version you may already have nfs or need to add it as feature (sorry don’t use Windows) , but above link might be a good start
so, if I make a share “SHARE” in the console (192.168.2.120) and create a new user call “ESXi” with password “Sharepassword” then from my client (ESXi) , I can use like \192.168.2.120\SHARE? with provided username and password?
Are there any patches or updates, softwares that can allow me to do the NFS configure from the console? and right now if I only have windows box, how can I verify it ( nfs share )?
NFS client on Windows is a feature. Not all versions of Windows have it though. check yours by going to control panel programs and features, turn it on if off, if you see “Services for UNIX based applications” then chek it and click ok this will install it and install the “mount” command as well.
If not found, Windows still provide Unix services as standalone download, again, only works on certain versions. check it out here
