Is there a way to roll back?
Hi @SBrown,
I removed both drives, I get the same error (500 error, connection refused). I think my drives are ok, but the enclosure might be bricked.
What are the next steps?
@antoniov8, Please help me to have a case open in our CRM and share the case number thru private message.
https://support-en.wd.com/app/ask
Thanks,
I have both a pr4100 and ex4100. After updating to os5 - I could sign in from the internet but could not get to my dashboard. I either got a 403 error or simply a blank page on my Mac. After hours of useless tech support and multiple promises of calls back from higher tier tech support (which never happened), I still was unable to access the dashboard. I finally connected to a completely different router with its own internal network. I was able to see the dashboard. When I reconnected to my home network - couldn’t see the dashboard again. Finally I noticed that I had manually forwarded the ports in os3 to the individual NAS units. I removed the manual port forwarding and was immediately able to see my dashboard. So simple I don’t know why WD tech support could not figure it out. They had even been remotely on my computer to try to fix the problem and couldn’t. Anyhow, I hope this helps some of you.
OS5 admin access using powershell & OpenSSH
This is what I’ve done to do the SSH with powershell rather than Putty.
install OpenSSH in powershell
NAS02
Public IP port forward 80 on router to another port number:
123.123.123.123:8082
SSH User: sshd@123.123.123.123
The OpenSSH command line in powershell:
ssh -f sshd@123.123.123.123 -p 22 -L 8082:123.123.123.123:8082 -N
-f sends the ssh command to the background so that you don’t have to keep powershell open
“sshd” is the built in SSH user on the MyCloud
123.123.123.123 is the public IP (obviously I changed it from my actual NAS IP) of the MyCloud
22 is the public port on MyCloud that SSH is published to
-L is local port, so your localhost:8082 will be forwarded
-N instructs OpenSSH to not execute a command on the remote system
So once you run the ssh command in powershell (admin) window you just open localhost:8082 in your browser and the NAS thinks you’re in it’s local subnet
