No issue with video, sound starts and after few seconds sound stops for every m2ts clips recorded from my panasoinic HD camcorder. Not sure why?
Please post the full TEXT output of MEDIAINFO for such a file.
General ID : 1 (0x1) Complete name : I:\New folder\08-17-2013_074338.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 206 MiB Duration : 1mn 9s Overall bit rate mode : Variable Overall bit rate : 25.0 Mbps Maximum Overall bit rate : 28.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.2 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Format settings, GOP : M=3, N=30 Codec ID : 27 Duration : 1mn 9s Bit rate mode : Variable Bit rate : 23.8 Mbps Maximum bit rate : 25.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 59.940 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.191 Stream size : 196 MiB (95%) Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 1mn 9s Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -34ms Stream size : 2.11 MiB (1%) Text ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 1mn 8s Delay relative to video : -34ms
Should have pasted better than that ?
I can’t see anything that would create audio issues (but it is hard to read)
One thing I do see is for the video - High@L4.2… I don’t think thats supported ?
- MPEG2 MP@HL up to 1920x1080p24, 1920x1080i30 or 1280x720p60 resolution.
- MPEG4.2 ASP@L5 up to 1280x720p30 resolution and no support for global motion compensation.
- WMV9/VC-1 MP@HL up to 1280x720p60 or 1920x1080p24 resolution. VC-1 AP@L3 up to 1920x1080i30, 1920x1080p24 or 1280x720p60 resolution.
- H.264 BP@L3 up to 720x480p30 or 720x576p25 resolution.
- H.264 MP@L4.1 and HP@4.1 up to 1920x1080p24, 1920x1080i30, or 1280x720p60 resolution.
Just tried a sample I found here, and it looks like its the same specs, and it played all right on my WD Live Hub.
http://forum.videohelp.com/threads/340778-Can-I-use-this-WD-TV-devise-to-play-AVCHD-video-files
Post #9
Here is the spec
General
Complete name : G:\Downloads\10-29-2011_065645.m2ts
Format : BDAV
File size : 22.9 MiB
Duration : 6s 963ms
Overall bit rate : 27.6 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format settings, ReFrames : 4 frames
Codec ID : 27
Duration : 6s 974ms
Bit rate : 26.0 Mbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.209
Stream size : 21.8 MiB (95%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 7s 8ms
Bit rate : 256 Kbps
Bit depth : 16 bits
Sorry about that… how is it now?
Is following supported?
I just got player yesterday becuse my Seagate palayer was not playing Video smoothly from my mt2s files. This player plays video fine but having audio issue. Audio start for every clip recorderd from Panasonic HD camcorder but audio stops after few seconds. Tried few mux software for different container but it didn’t help. Everything plays fine on PC with simple VNC player.
Appriciate your help if you know if this will play or not? I need to return it within 15 days if it will not work.
General
Format : BDAV
File size : 206 MiB
Duration : 1mn 9s
Video
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 1mn 9s
Color space : YUV
Bit depth : 8 bits
Audio
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1mn 9s
Bit rate : 256 Kbps
Bit depth : 16 bits
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Duration : 1mn 8s
If you look at my previous post, download the sample and see if it plays, it worked fine on mine ?
But is it an old Live you have, or is it the newer Live Streaming Player ?
#9 and #10 file works fine but those are only few seconds file and mine also works fine for few seconds…
I uploaded mine #15. Can you try that? Audio stops after few seconds whwn I play mine.
Thanks for helping me out.
This is 3rd gen new player just bought yesterday. I also uploaded latest FW on it.
Thanks again
That file type isn’t supported.
Frame rate is 60p. 1920x1080 supports max of 24p:
Any media player that can play 1920X1080 60p m2ts file?
So is it a buffer thing that it plays the complete video and drops out sound after 5 seconds? I’ve just tried the file and it’s really weird.
That would be my guess.
Audio is usually the first thing to go when the WDTV loses “sync” within a stream.
