So I just go my brand spanking new unit from amazon, and started putting it through it’s paces. So far it plays mkvs and avi’s fine, and also does pandora fine.
But, when I do netflix, there is video but no audio!
I am using HDMI out from WD TV LIVE to my onkyo receiver.
PCM/dolby digital/dts works fine for mkvs/avis, and pandora plays fine, so how come netflix has no sound?
also I noticed, if I try to play anything else after exiting netflix, sound is all distorted and I have to power cycle the unit to get things sounding ok again.
This sounds like an issue with your receiver for sure. Try plugging the device directly into your TV and see if sound plays - if it does, than you can be sure thats where the issue lies.
I’ve no trouble with netflix sound however since I upgraded to the latest firmware (1.04.12) I sometimes get distorted sound for any music/video from any source - A power toggle off/on fixes the problem - A bit annoying but the power toggle is fast
its you settings thats what mine was doing you have to change the setting for it you have 2 choices can tell u step by step i dont remember steps i just went and started changing things but i’ll try to go back in if i can ill post it
