Passport Unlocker Problem?
Hello all! Recieved my 1TB Passport Essential SE yesterday and loved it! However, I decided to add the WD Smartware to the Passport so I could lock it down. Now, I am prompted to submit my password. That works fine. My password works and the drive unlocks like I intended. Unfortunately I only have access to the unlocker partition which is 22.7Mb. The rest of the drive is not accessible that I can see.
Doing a search, I saw at least one other person with this problem but didn’t see any solutions. Any ideas? I’ve upgraded both the firmware and the software to no avail… ;-( It might be worth mentioning that prior to installing the WD Smartware, the drive worked fine. Had access to the entire 1TB.
Thanks for any help!
Shawn
It is possible that you have a corrupted partition if you are unable to see the drive icon along with the Smartware software icon. I would recommend you to test the drive on a different computer and if the issue remains, you might need to format the drive.
What capacity is reported by tools such as HD Sentinel or HDDScan?
HD Sentinel (DOS / Windows / Linux):
http://www.hdsentinel.com/
HDDScan for Windows:
http://hddscan.com/
