Passport Wireless Pro application questions, please help
Hello everyone, I am going to order two Wireless Pro for data back up but after I read the manual, I still have a few questions, could anyone please shed some lights?
  1. Can I connect 2 x Wireless Pro at the same time to just 1 x computer to transfer files between them? e.g. Like transferring videos on first Wireless Pro and music to the second Wireless Pro or vice versa.
  2. Can I connect it to two DIFFERENT OS device at the same time using wireless connection? e.g. PC and Mac, PC and iphone, Android and iphone…etc.
  3. Can I use the USB 2.0 and USB 3.0 port to transfer data at the same time? e.g. Plugging both to 2 computers to transfer data at the same time.
  4. When using “Wireless Network Connection” type connection, does that mean the moment it connects, everyone can access the drive right away and all I can do is to uncheck the “Share content on this network” check box after a connection been made to stop others from accessing my drive?
  5. What’s the longest range for a good connection between Wireless Pro and a device?
Sorry for so many newbie questions but thanks so much for reading them all, thanks!
Hi, I will try to answer your questions the best I can.
Yes you can usb the USB connection.
You can connect it to Mac and Windows directly using the USB port, on Android and iOS you will need the WD My Cloud app.
You can use either/or, not both at the same time.
http://support.wdc.com/knowledgebase/answer.aspx?ID=14195
