Hello WD Boards,
Again I find myself breathing a little harder thanks to the Live Hub. Earlier, despite having a proper USB Wifi adapter, I couldn’t get a proper DNS number to come up and connect. So, I grabbed an Airport Express and extended my network, then used an ethernet cord to hardline the Hub to the express. This has worked.
Then a hitch came up and all of my Mac’s couldn’t access the folders on the Hub. It became a drop box only folder. I could only add (write) and not read. I got around this by setting up a username and password and logging in to the server. A minor inconvenience.
Now, I’ve my newest problem, I’m trying to transfer more MKVs to the Hub and when I transfer them they either show up in a document form, or if they do transfer as an MKV they immediately disappear from the folder on my computer. When I go over to the hub, they’re there, but unplayable. I get an error message lecturing me about supported formats. This has also happened with standard MP4 files. Which are supported.
Has anyone had this issue or know of a solution for it?
Additionally, the Repeat All playback function does not and has never worked!
— Update ----
Have installed the newest firmware and now I am completely unable to transfer any files to the Hub from my computer. I’ve tried reseting everything and nothing seems to work.
Repeat All video playback function still is not working.
