Hi there,
I recently got the WD TV Live Streaming Media Player. I tried to play a movie trailer in .mov format from iTunes, but it did not work. I copied the .mov file onto a USB stick, but I got the error message that the file format was not supported. Althought it says on the package that .mov is supported. What could be the problem? Are the iTunes trailers DRM protected?
It was a trailer in Full HD resolution…
Thanks for any help!
