Please Help Me! Yellow flashing led after static IP
I everybody.
That’s my situation: i bought a 4tb My Cloud from Amazon 3 days ago.
It worked fine till today when I changed from DHCP to static IP to have best network performances. After that I can’t connect to my device: no webpage, no ping, no network activity. The disk is working but I can do nothing. I’m desperate…
Any solution? The 4 seconds and 40 second reset doesn’t work…
My idea is to create an RMA and ask for the change with new one… Is it possible?
When you did the 40-second reset, you pressed the button in BEFORE applying power, correct?
Yes, but did not solve my problem…
Use the following link to open the User Manual and go to page 10 or click on LED’s under bookmarks. You will see the two problems that cause a blinking yellow light on the front of WD My Cloud.
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705103.pdf
