Hello
is it possible to connect a USB HUB (maybe with 4 or 8 ports) to a WD TV LIVE HUB (this model: http://support.wdc.com/product/images/groupfs_1003.jpg or http://support.wdc.com/product/download.asp?groupid=1003&lang=en))
I have 4 USB Hard Drives and I want to buy a USB HUB only if it is gonna work
Regards
Jeremy
You don’t have a WD TV Live Hub. You have a WD TV Live Plus.
I’ve got a WDTV LIVE HUB
http://support.wdc.com/product/download.asp?wdc_lang=en&fid=wdsfWDTV_LiveHub
and a cheap (non-powered) 10 Port Hub and it worked fine for me
(Note: WDTV Live Hub … On the Left of Picture Decommissioned Live & Gen1 on the Right
