Can someone please provide guidance on what I should do. Recently I unplugged my WD Cloud storgae from my PC for cleaning the room.
When I try to reconnect the power source the power led light shows steady yellow/orange for a couple of minutes then it starts blinking and stays that way. It goes dead (blank) as soon as I connect the network wire. If I remove the network wire - the yellow flashing light comes back on after a few minutes. All this while I can hear the disk spinning in the background.
All along I can hear the disk spinning inside making the noises. Not sure what to do. I have several important backups on the disk.
I have tried to unplug the power a few times and plug it back - with the same result.
I have not done any type of reset or anything else at all.
