PR4100 4x6TB WD RED, red drive light no errors
Hi Yesterday morning my bay 3 ad 4 led under the drive bay went red, the sistem say they have Smart Error, but In smart data I cannot see any, do I have to put new discs?
Here the log.
TimeStamp: Wed Jan 20 23:30:51 2021
----------------------------------Drive1------------------------------------------------------
smartctl version 5.38 [x86_64-intel-linux-gnu] Copyright (C) 2002-8 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION ===
Device Model: WDC WD60EFRX-68L0BN1
Serial Number: WD-WX11DC57S0NH
Firmware Version: 82.00A82
User Capacity: 6,001,175,126,016 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 9
ATA Standard is: Not recognized. Minor revision code: 0x1f
Local Time is: Wed Jan 20 23:30:51 2021 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (2984) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 203 196 021 Pre-fail Always - 8816
4 Start_Stop_Count 0x0032 093 093 000 Old_age Always - 7673
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 051 051 000 Old_age Always - 36128
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 40
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 17
193 Load_Cycle_Count 0x0032 198 198 000 Old_age Always - 8070
194 Temperature_Celsius 0x0022 115 100 000 Old_age Always - 37
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
1 Extended offline Completed without error 00% 36127 -
2 Extended offline Aborted by host 90% 36115 -
3 Short offline Completed without error 00% 28945 -
4 Short offline Completed without error 00% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
----------------------------------Drive2------------------------------------------------------
Serial Number: WD-WX11D3678EAD
ATA Version is: 9
was never started.
been run.
data collection: (5204) seconds.
command.
power-saving mode.
3 Spin_Up_Time 0x0027 203 196 021 Pre-fail Always - 8841
4 Start_Stop_Count 0x0032 093 093 000 Old_age Always - 7862
193 Load_Cycle_Count 0x0032 198 198 000 Old_age Always - 8235
No Errors Logged
1 Extended offline Completed without error 00% 36128 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
----------------------------------Drive3------------------------------------------------------
Serial Number: WD-WX11D36JRCJ0
ATA Version is: 9
was never started.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
data collection: (5564) seconds.
command.
power-saving mode.
4 Start_Stop_Count 0x0032 093 093 000 Old_age Always - 7859
193 Load_Cycle_Count 0x0032 198 198 000 Old_age Always - 8246
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 3
No Errors Logged
1 Extended offline Completed: read failure 90% 36116 194480160
2 Extended offline Completed: read failure 90% 36115 194480160
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
----------------------------------Drive4------------------------------------------------------
Serial Number: WD-WX11D36JREK6
ATA Version is: 9
was never started.
been run.
data collection: (2384) seconds.
command.
power-saving mode.
3 Spin_Up_Time 0x0027 231 196 021 Pre-fail Always - 7433
4 Start_Stop_Count 0x0032 093 093 000 Old_age Always - 7806
193 Load_Cycle_Count 0x0032 198 198 000 Old_age Always - 8188
194 Temperature_Celsius 0x0022 116 101 000 Old_age Always - 36
No Errors Logged
3 Short offline Aborted by host 30% 36112 -
4 Short offline Aborted by host 40% 36112 -
5 Short offline Completed without error 00% 28945 -
6 Short offline Completed without error 00% 0 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
