I’m thinking about running my PR4100 with 4 wd red 8 tb drives, I have two already.
My concern is though, that when I just run the 2 drives I already have, temps are around 45-50 celcius at idle, which, I expect, will be higher when two more drives are added, and also under load.
Will the PR4100 and drives be able to work with temps that high?
Running default WD firmware.
Thank you
Its fine if you are using compatible WD RED HDD. https://support-en.wd.com/app/products/product-detail/p/139#WD_compatibility
The WD RED 8TB HDD tem spec is listed in our data sheet here: https://documents.westerndigital.com/content/dam/doc-library/en_us/assets/public/western-digital/product/internal-drives/wd-red-hdd/data-sheet-western-digital-wd-red-hdd-2879-800002.pdf
We also have 32TB (4x 8TB) SKU for sales.
Thank you. I see that the operating temp for the drives is 40 to 70 celcius. I just thought that 45-50 per drive, sometimes more (have seen it hit 55 celcius) when under load, was a bit much for just two drives. Guess it’ll be fine.
