PROBLEM 3TB Hard disk & Firmware 1.06.15_V
My 3TB External Western Digital hard disk is not detected from my last firmware update…
some else having problems?¿
MAGICIAN
hi there
  • it should have been,it should take some more time but would finally mount .
  • pls check :
* latest updates for your 3tb book ? Plug in your 3tb via usb to your laptom/pc which has net connection and check updates
* library is set off  or  on ? [within you wd media player]
* are you sure it worked perfectly with the latest fw - say a day ago ?
regards
pawson
Definetively my WD Live doesn’t see my 3TB Book…
The last 1.06.15_V firmware fu… this capability
