Problem playing files, lags every five second or so
Hi!
I’ve got some issues playing a couple of files on my WD tv live hd media player. It very rare cause usually the player has no problems what so ever, but i’ve come across 3-5 files that plays fine and audio is fine, except there’s a lag each and every five seconds or so when im playing the file.
All files except one is in the format mpeg-ts but the last one was mkv. Im thinking about converting these but haven’t found a decent program yet and don’t know if it’ll solve the issue.  I’ll give you the information about the video and hopefully someone can help me.
File 1.
Description:
Format :   MPEG-TS
File size : 4.37 GiB
Duration : 2h 0mn
Overall bit rate : 5 196 Kbps
Maximum Overall bit rate : 18.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Duration : 2h 0mn
Bit rate : 4 388 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 60.000 fps
Original frame rate : 50.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.079
Stream size : 3.69 GiB (85%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
file 2.
Description:
Format :   MPEG-TS
File size : 1.63 GiB
Duration : 46mn 17s
Overall bit rate : 5 038 Kbps
Video
Menu ID : 1 (0x1)
Format : AVC
Duration : 46mn 20s
Bit rate : 4 305 Kbps
Height : 720 pixels
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.078
Stream size : 1.39 GiB (86%)
file 3
Format : Matroska
Format version : Version 2
File size : 3.77 GiB
Duration : 1h 47mn
Overall bit rate mode : Variable
Overall bit rate : 5 016 Kbps
Encoded date : UTC 2011-12-26 13:40:11
Writing application : mkvmerge v3.2.0 (‘Beginnings’) built on Feb 12 2010 16:46:17
Writing library : libebml v0.7.9 + libmatroska v0.8.1
Video
Format : AVC
Muxing mode : Container profile=Unknown@0.0
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 47mn
Bit rate mode : Variable
Bit rate : 4 468 Kbps
Maximum bit rate : 20.0 Mbps
Height : 720 pixels
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.081
Stream size : 3.36 GiB (89%)
Default : No
Forced : No
Post the media info of   your movies:
http://wdc.custhelp.com/app/answers/detail/a_id/2745
