Hi guys,
I just recently got a WD Live TV hub and I’ve been putting all the HD videos I have onto it. The problem I have is that the Hub doesn’t “see” some of these videos. At first I thought it could be because of the size of the file (~4 - 10 GB) but I’ve read on numerous forums that people have had no problems playing files the size of 32Gb… so back to square one.
I assume it must be a codec issue so I’ve got some media info to share. The following is an MKV which the device can see and play:
General
Unique ID : 0 (0x0)
Complete name : Z:\Shows\XXXXXXX.mkv
Format : Matroska
File size : 1.46 GiB
Duration : 58mn 6s
Overall bit rate : 3 591 Kbps
Encoded date : UTC 2010-02-22 21:41:29
Writing application : no_variable_data
Writing library : no_variable_data
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 58mn 6s
Bit rate : 3 199 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.145
Stream size : 1.27 GiB (87%)
Writing library : x264 core 85 r1442tw
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=30 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=6 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=0 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3199 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 58mn 6s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 160 MiB (11%)
And this is an MKV the device cannot “see” (and therefore play):
General
Unique ID : 201418692919847073125178714347898708207 (0x9787D446CD8D47C2BC94B6DB6538A0EF)
Complete name : Z:\Movies\HD\XXXXXXX.mkv
Format : Matroska
File size : 4.36 GiB
Duration : 1h 40mn
Overall bit rate : 6 219 Kbps
Encoded date : UTC 2011-05-27 09:48:05
Writing application : mkvmerge v4.0.0 ('The Stars were mine') built on Jun 6 2010 16:18:42
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, ReFrames : 5 frames
Format settings, GOP : M=4, N=58
Duration : 1h 40mn
Bit rate : 4 709 Kbps
Height : 528 pixels
Display aspect ratio : 2.40:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.291
Stream size : 3.22 GiB (74%)
Writing library : x264 core 115 r1995 c1e60b9
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=24 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=4709 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 40mn
Bit rate : 1 510 Kbps
Bit depth : 24 bits
Stream size : 1.06 GiB (24%)
Title : English
Language : English
Can anyone help me out? I’ve trawled through the user manual but it’s not very specific saying only that it supports the codecs that are listed in the Media Info…
Many thanks!
