Ok, adjunto a continuación algunos ejemplos de ficheros AVI que NO se reproducen correctamente (información obtenida con mediainfo):
notworking01.avi
General
Complete name : notworking01.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 1.61 GiB
Duration : 1h 42mn
Overall bit rate : 2 252 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 1
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Custom
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 42mn
Bit rate : 1 401 Kbps
Width : 720 pixels
Height : 400 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.195
Stream size : 1 024 MiB (62%)
Writing library : XviD 64
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : 2000
Duration : 1h 42mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : 15ms
Stream size : 327 MiB (20%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Language : Spanish
Audio #2
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 42mn
Bit rate : 192 Kbps
Channel(s) : 2 channels
Stream size : 140 MiB (9%)
Alignment : Aligned on interleaves
Interleave, preload duration : 504 ms
Writing library : LAME3.98r
Encoding settings : -m j -V 4 -q 2 -lowpass 18.6 -b 192
Audio #3
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 42mn
Bit rate : 192 Kbps
notworking02.avi
General
Complete name : notworking02.avi
Format : AVI
File size : 1.91 GiB
Duration : 1h 40mn
Overall bit rate : 2 714 Kbps
Video
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 1h 40mn
Bit rate : 2 188 Kbps
Width : 696 pixels
Height : 392 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.321
Stream size : 1.54 GiB (81%)
Writing library : DivX 3013
Audio #1
Format : AC-3
Codec ID : 2000
Duration : 1h 40mn
Bit rate : 384 Kbps
Bit depth : 16 bits
Delay relative to video : 24ms
Stream size : 276 MiB (14%)
Audio #2
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 40mn
Bit rate : 128 Kbps
Stream size : 92.0 MiB (5%)
notworking03.avi
General
Complete name : notworking03.avi
Format : AVI
File size : 349 MiB
Duration : 41mn 31s
Overall bit rate : 1 176 Kbps
Writing application : Nandub v1.0rc2
Writing library : Nandub build 1852/release
Video
Format settings, BVOP : 2
Codec ID : XVID
Duration : 41mn 31s
Bit rate : 899 Kbps
Width : 544 pixels
Height : 304 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.217
Stream size : 267 MiB (76%)
Writing library : XviD 1.0.3 (UTC 2004-12-20)
Audio #1
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 41mn 30s
Bit rate : 128 Kbps
Delay relative to video : 8ms
Stream size : 38.0 MiB (11%)
Interleave, duration : 24 ms (0.60 video frame)
Audio #2
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 41mn 30s
Bit rate : 128 Kbps
notworking04.avi
General
Complete name : notworking04.avi
Format : AVI
File size : 1.90 GiB
Duration : 2h 11mn
Overall bit rate : 2 069 Kbps
Video
Format settings, Matrix : Default (MPEG)
Codec ID : XVID
Duration : 2h 11mn
Bit rate : 1 415 Kbps
Width : 720 pixels
Height : 384 pixels
Display aspect ratio : 1.85:1
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.213
Stream size : 1.30 GiB (68%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio #1
Format : AC-3
Codec ID : 2000
Duration : 2h 11mn
Bit rate : 192 Kbps
Channel positions : Front: L R
Bit depth : 16 bits
Stream size : 181 MiB (9%)
Interleave, duration : 42 ms (1.00 video frame)
Audio #2
Format : AC-3
Codec ID : 2000
Duration : 2h 11mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Stream size : 422 MiB (22%)
