Questions about making themes for the SMP
Hey guys!
Im new to the WDTV Live SMP, to this forum and to XML editing.
I was looking for the default Mochi theme for download, so I could edit the layout of the gallery browse page etc.
So I found a link to it posted by Tinwarble, but it was posted in the thread “List of Themes” in the “Hub Themes”.
Is this the same version of the Mochi theme to the SMP? Many of the themes made for the HUB dont work properly or at all with the SMP, so I wouldnt want to edit tons of stuff, just to find out im editing the wrong Mochi theme/version.
I’ve uploaded the Mochi file via the web interface, and roughly it seem to run pretty well.
Still tons of functions and stuff I didn’t test tho, so I can’t be sure if its right or wrong Mochi version.
I have downloaded this, and uploaded it to my SMP via the web interface, and it works pretty well, but I havn’t testd all the features.
2nd question,
As it is right now, every update I make to a xml file, I have to re-pack the hole 20MB theme, and reupload it thru the web interface.
JoeySmyth made a post about there beein another way, I cant quite get it tho.
Quote from Joey
“If you just to change or modify ‘One’ View… then all you need to do is modify the Appropriate XML create a Folder…
eg. Jonnie’sMod   and copy the ‘One’ Single XML into this Folder and unpload it to the .wd_tv/theme/”
I tryed zip the one single xml file, and even without zipping it, none of the methods worked, said something about the size if Im not mistaken.
Is there another way to access .wd_tv/theme/?
Thanks in advance
I have not messed around a lot with themes, but I know that the Mochi theme should be compatible with the WD SMP.
