Remote access
Hi, i would like to access my mycloud folder when i’m at school, so remotely and without the wd sync software.
With the old version, i was able to add a network drive (mapping) when i was outside of my house with the “add explorer” option.
Now, with the new version, i don’t see this option on www.wd2go.com . So how can i do this?
Why i want to do this, it’s for “save as” new document directly in my mycloud drive.
Thx for the help.
Miistral
Hi, unfortunately on the new www.wd2go.com web page, the options to map a network share is not there, as this used Java and is no longer used.
In my opinion, not supporting a network share is a shame. The device is sold as a cloud device and accessing it as a network drive is basic functionallity of such a device and actualy the reason for me to buy one. It this functionality to be added again later?
Look into NetDrive. You might have to open a few ports on your router to get it to work.
netdrive is not really a solution. I have purchase this thing because on the box it was listed the share was a function.
I has work 1 month before they removed it
i really need to find the solution to do it
