Rpm, disk speed in my cloud solution
PLease, I would like to know the speed of disk’s in My Cloud, and My Cloud duo products.
speed in rpm (5400, 7200, etc).
Best regards,
The single bay My Cloud units typically use WD Red drives within the enclosure. The WD Red specs can be found here:
https://www.wdc.com/products/internal-storage/wd-red.html#WD100EFAX
You may want to look at this too.
What device do you have or what are you thinking about buying?
Are you asking about the MyCloud, or the MyCloud Home?
There’s not MyCloud Duo that I’m aware of. There is a MyCloud Home Duo, and a MyBook Live Duo:
http://wdstagingsplit.staged-by-discourse.com/
